Software to Edit PDF Files?
Discussion in 'Software' started by OneSeventeen, 11 Sep 2007.
Thread Status:
Not open for further replies.
  1. OneSeventeen
    OneSeventeen Oooh Shiny!
    3 Apr 2002
    I'm looking around for good software to simply edit existing PDF files.
    Adobe refuses to use the word "Edit" on any of their comparison matrices so I'm at a loss as to which app I really need.
    I can get standard for $100, and Pro for $150, but it will only be used to grab existing PDF's and delete some stuff, add some stuff, and alter other stuff.
    Any tips on what I need? (Any tips on free software that does the same thing?)
    All of this will be done in Windows XP.
  2. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    I know OpenOffice can save documents as PDFs. Not sure if it can edit ones it didn't create, but it might be worth a shot, before you spend a hundred or two dollars on Adobe software.
  3. Atomic
    Atomic Gerwaff
    6 May 2002
    I've had the Pro version in jobs and it's been the one people get when they need to edit pdf files.
  4. zr_ox
    zr_ox Whooolapoook
    5 Jan 2005
    If you have Adobe Acrobat Pro you have the option of installing Adobe Designer, this gives you massive flexibility for editing and creating interactive PDF files.
  5. OneSeventeen
    3 Apr 2002
    Looks like we will probably go with Pro, but keep in mind this is for someone who only needs to edit simple PDF's for reporting purposes, not for design or creative purposes.
  6. customh
    customh conflagration.
    22 Oct 2005
    I agree, is there something free? or cheaper?
  7. evilgreenie
    evilgreenie Standby for Main Engine Burn
    30 Aug 2002
    Depends what edits you want to do & on which OS.. Most editing is done on the source document with only touch-up/page rotation etc done in PDF
    I hear good things about PDFill editor tools (windows, free)
    http://pdfill.com/pdf_tools_free.html
    or PDFEdit
    http://www.pdf995.com/pdfedit.html
    Personally I use Acrobat Standard which is good for pretty much everything except form creation, but its expensive!!
  8. rpatterson
    rpatterson What's a Dremel?
    3 Jan 2008
    Richard
    A UK company called Iceni ( http://www.iceni.com ) has very good tools in this area.
    Gemini ( http://www.iceni.com/gemini.htm ) has a ton of PDF conversion options with output into multiple formats.
    Then Infix PDF Editor allows the editing of the PDF files - as well as a load of extraction utilities. It has all the page manipulation functions (add, delete, move, rotate, etc) - it also has a fully functioned text editor that allows text to be reflowed, font changed, size changed & text block moved. Image editing, scale & image movement is also supported. See http://www.iceni.com/pdf_editor_infix.htm for free download.
  9. tk421
    tk421 Idiot.
    15 Jan 2002
    better yet - skip adobe altogether.
    make your documents in Word. Edit documents in word. save as PDF with the free Cute PDF writer.
  10. ryanjleng
    ryanjleng ...
    15 Nov 2007
    This is probably the best editor with really accurate PDF conversion tool -Nitro PDF Professional
    Fantastic app. but commercial
  11. cpemma
    cpemma Ecky thump
    27 Nov 2001
    This thread is 3 months old, if I had a suspicious mind I'd think Mr Patterson was pimping. :eeek:
Thread Status:
