Was at my local department store (zellers) when I happened to stumble upon the above proudly displayed on an end-cap (end bit of a shelving unit). Not quite sure I understand the intended use, and figured I would share it with you lot, see your thoughts.
I'm not sure what your question is - If you're asking how it works, the solar panel charges the battery, which then powers the light when it's dark.
Steveo, what about that rotary drier? You know the one that spun round through water power when it rained?
