{solved} - a bit urgent problem. voip & porting sound
Discussion in 'Tech Support' started by Arkantos, 3 Aug 2006.
  1. Arkantos
    Arkantos What's a Dremel?
    1 Apr 2006
    big problem, i have.
    the setup.
    2 machines, i shall call them 'shop' and 'home'....
    both are the same configuration.
    D945Gnt mobo Intel Original
    P4 HT procs Intel
    512 MB Hynix
    160 GB Seagate.
    there is a microphone connected to the home comp.
    i need to listen to the 'home' mic from the shop - as soon as i turn on the shop comp - so pressing any keys / mouse or logging in, for the link is out of the question.
    is there any software that will do this??
    Ark.
  2. fev
    fev Industry Fallout
    13 Aug 2003
    disable login,
    set mouse macro up to login to skype and dial home
    set home to auto answer
    done
  3. Arkantos
    1 Apr 2006
    Aah! many thanx.
    but none of the PCs are connected to the internet. i should have mentioned that in the previous post. i need something that will use the LAN connection...
    will skype work without intenet?
    Ark!
  4. fev
    13 Aug 2003
    skype can't work without the internet, however there are "LAN-based" VOIP programs, use google
  5. Arkantos
    1 Apr 2006
    many thanx, i found one, that had a server and client system. so i used that and used VNC to switch on the server from the home.
    thank you.
    Ark!
