Linux [Solved]How to Partition a Hard drive Using Ubuntu 10.10??
Discussion in 'Tech Support' started by DeafGamer2015, 8 Feb 2012.
  1. DeafGamer2015
    DeafGamer2015 Minimodder
    5 Jun 2010
    Hello Bit-techers,
    I'm a bit stumped on how to create an partition on my hard drive.. I'm currently using Ubuntu 10.10 right now. Does anyone know how to do this?
    I am planning to install Windows on this laptop in the next few months and I don't want to deal with buying a 2nd hard drive right now due to the high prices due to the flood.
    So if you know how to do that using Ubuntu 10.10 please make it clear enough for me to understand so I can figure how to do this.
    Thanks for taking your time out to read this.
    Gaming_freak_10
    By the way, Bit-Tech.net forums rules! :rock:
  2. Gurdeep14
    Gurdeep14 Minimodder
    25 Apr 2009
  3. moorsey
    moorsey What's a Dremel?
    10 Oct 2009
    indeed, grab the gparted live CD, so you don't need Ubuntu really.
    Burn the disc, boot up to it, then partition away
    You can do the same from an Ubuntu live cd, as gparted is installed by default, so if you have booted upto ubuntu, then find the gparted app and off you go
    DeafGamer2015 likes this.
  4. DeafGamer2015
    5 Jun 2010
    Thank you both :) here's some +rep coming your way both of you!!
    [Edit]:I just burned the gparted live to a blank cd.. will handle the rest later when i get an hard drive for backup, just don't want to lose all of my data in case if i screw up the partition thing.
  5. monkiboi
    monkiboi Minimodder
    5 Feb 2012
    If I understand you correctly you already have Ubuntu and are re-partitioning the drive so that you can dual boot Windows? If I have it right you'll need to look up on how to fix the mbr/bootloader afterwards as Windows tends to re-write it for Windows only.
    If I've misunderstood then ignore me :)
  6. DeafGamer2015
    5 Jun 2010
    no you're correct there Monkiboi.. but i'm just going to move my stuff off ubuntu to another hard drive then install the windows on the original hard drive then re-partition that and install Ubuntu alongside.. and there we go.. a bit lot of work but not that bad really..
  7. DeafGamer2015
    5 Jun 2010
    UPDATE!!!! Just installed Windows XP Pro on this laptop.. repaired the MBR boot loader now transferring my stuff.. 30.1 GB worth of stuff to be transferred..
    Edit: it looks like I can't back up my stuff on Windows for some reason.. I guess Windows is now for gaming only.. meh it was worth a try.
    Linux: Casual Surfing
    Windows: Gaming..
  8. moorsey
    10 Oct 2009
    Whats the issue? Are you running the copy in Linux, copying files from Linux to Windows partitions?
    I have only ever had trouble with this when the Windows file system had been hibernated or similar, Linux has issues working with the NTFS file system in this state, very bizarre issue.
  9. DeafGamer2015
    5 Jun 2010
    it says I can't burn my stuff to blank dvds to backup.... and it's from Linux to Windows partitions yes.. and I can't backup my stuff even through Windows or Linux..
