Windows Some more excel help!
Discussion in 'Software' started by matt_lumley, 18 Sep 2013.
  1. matt_lumley
    matt_lumley You're only supposed to...
    28 Apr 2010
    Hi Guys,
    Just a quickie!
    Got a huge excel spreadsheet with the following columns:
    Forename
    Surname
    Telephone
    Email
    Site
    Year of study
    It is filtered so I can see specific sites and their staff.
    What I need is something to automatically find all clients from say the sugden centre and export it to a new tab/page/spreadsheet, same for the aquatics centre and then again for those who havent specified so I can send it to the relevant sites.
    Can any one help?
    Thanks in advance
    Matt
  2. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    vlookups / hlookups seem to be what you will want, then copy and paste the values into the spreadsheet you will send,
  3. dynamis_dk
    dynamis_dk Grr... Grumpy!!
    23 Nov 2005
    Depending on how many different site your dealing with, if its just the 3 the vlookup might work well enough however its theres several I'm not sure if this will maybe work for you: http://en.kioskea.net/faq/7053-excel-macro-to-create-new-workbook-and-copy-data
    As it stand you would just need to adjust the reference in the code to the column your sites are listed in.
    It searches the document, selects the unique values (in site in your case) and create/saves a new spreadsheet for each site. I've tested it and it work well, just need to make sure you save the spreadsheet first as the macro saves the new spreadsheet files in the same location
    If you want to give this macro a go, let me know if your struggle with it or anything - its been a while but vb was my thing in the day so I might be able to help. I've edited the code and make it easier to read/edit so can always provide it if it helps
  4. dynamis_dk
    23 Nov 2005
    I like to have a play with excel so I had another play with this :)
    Managed to fix up a few bits to make it easier to use so as long as the spreadsheet is formatted with your field titles along the top it should be able to spit the sites into separate tabs all within one workbook
