i was checking the 24" LG W2453SQ-PF at ebuyer and i checked the same same product at the LG website the description for this product is different and most important for me i still do not know how and what kind of inputs this monitors has? i was just about to buy it cause looks like a good monitor for £150 but now i dont know. any help please!
I searched a couple different sites the only one I found with my quick search that mentioned ports was http://www.laptopsdirect.co.uk/LG_F...idescreen_TFT_Monitor__W2453SQ-PF/version.asp found under "Tech Spec".
The ebuyer link you provided shows the info you need: * Analogue video Signal 1 x VGA - 15 pin HD D-Sub (HD-15) So basically this monitor only has one input (VGA)
It's an old LG Model (already discontinued). It also has built in TV tuner and 2 x HDMI outputs, so I guess they sacrificed high end inputs for that... but for the price you could get a similar display with at least DVI inputs. Just look for one that doesn't inlcude the TV Tuner (Unless you wanted that of course).
really only one VGA input , in 2010! ^^ com on! what they where thinking when they were building this monitor? no DVI or HDMI?! anyway i ll go get the LG W2361V-PF 23"..looks good! thank you for your replies guys
