Graphics Sorry Guys
Discussion in 'Hardware' started by Bloodburgers, 29 Oct 2009.
  1. Bloodburgers
    Bloodburgers Minimodder
    30 Apr 2009
    I am sure most people are fed up with answering questions about graphics cards atm with the release of the new ati range and all the confusion with nvidia's however i have to ask one more. so apologies to those already at breaking point.
    My current spec is as follows;
    CPU: Intel Q6700 @ 3.6Ghz
    Motherboard: DFI LP LT-X48-T2R iX48 S775
    GPU: 512M GIGABYTE ATI HD3870 GDDR4 @ 825Mhz/1150Mhz
    RAM: 2 X 2G OCZ Reaper-X pc2-8000 @ 1066Mhz
    HDD: 500G SAMSUNG SATA2 HD501LJ
    PSU:CORSAIR HX 520W MODULAR PSU.
    Now with that cleared up. I am looking to udrage my GPU as my trusty 3870 is now a little long in the tooth.
    I currently play my games at 1680x1050 on my 22" monitor. At this resolution there is little point in me buying a 5850 or higher as it would most likely be wasted and i very rarely game on my 52" tv.
    The titles that i currently enjoy playing are pretty much the usual jumble. COD4, Grid, Empire TW, oh and not forgetting X3.
    So i will want something i can plug in and run everything at my required rating at max (although this may be hard on the empire front).
    I have no real affinity for either camp although i would lean more to ati due to having a bad experience with Nvidia back in the FX days. Despite having a crossfire capable board i have never been enamoured by the idea however should a bargain arise i could be swayed assuming my psu could take it.
    So now the crux of the matter please could i have your 2 pence worth to help me decide.
    Stank you for your patience. And thank your for any advice you may have.
  2. Kyocera
    Kyocera The Garden of Evil
    9 Sep 2009
    How much money?
    and then we'll talk.
  3. trig
    trig god's little mistake
    10 Aug 2006
    i would think a 5850 would be perfect for the games you play and the resolution...if it fits your budget
  4. yh125d
    yh125d Total noob
    29 Oct 2009
    Nvidia of today and nvidia of the FX generation are totally different, I wouldn't rule them out just for that ;)
    For that res, something 5850/GTX285 ish is already starting to get close to overkill, so something higher doesn't really need to be considered unless you want to upgrade your monitor soon. Even a 4850/GTS250 can pretty well max out most games at 1680x1050. A 5770 I think would be a good match of features/performace/price for you
  5. Rotcrack
    Rotcrack Food Maestro.
    24 Jul 2009
    Following on with trig you could get a 4870 if the HD 5850 seems a little pricey. And if you want more power than than HD 4870 get a HD 4890.
  6. Bloodburgers
    30 Apr 2009
    Well atm i was looking round the £150 mark guessing it would be between 265-275 and 4850-4870. However if the difference in price were to be matched by a suitable increase in real world gaming performance i could be swayed
  7. Rotcrack
    24 Jul 2009
    For about that price you could get a *refers to magazine* 1GB Sapphire HD 4890 Vapor-X at £161.22. If you are willing to push the price up a bit you could get the Sapphire Atomic HD 4890 which is essentially the same except it has been factory overclocked.
  8. barndoor101
    barndoor101 Bring back the demote thread!
    25 Oct 2009
  9. Rotcrack
    24 Jul 2009
    Dont buy the power color!:thumb:
  10. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    I've got the same PSU as you with a similar spec rig (E6850 dual3ghz, Asus P5KC, 4x1gb 4-4-4-12-1t RAM, WD Cav Black 640gb, Dell 2007WFP 1680x1050 20").
    Very happily running a HD4870 1GB I got 2 months ago for £114, having upgraded from a HD3870. My frame rates in World of Warcraft, got a roughly 30 fps global boost (although I vsync to cap at 60 so its not always visible) on full sliders to the maxxxxxx!
  11. mbvg
    mbvg e5300 all the way
    7 Oct 2009
    well i don't want to spend alot on a GPU but want to play Empire total war Help
