Sound card & Surround Sound
Discussion in 'Hardware' started by Tsen, 30 Sep 2007.
  1. Tsen
    Tsen Steeped In Romance
    29 Apr 2006
    Okay, so I've got $350 to spend on a sound card and a surround sound system.
    I'm thinking about either the X-Fi Extreme Gamer (link), but would the X-Fi Extreme Gamer Fatal1ty (link) give me good enough quality to justify the added price?
    Then, I'm looking at a Creative Inspire P7800 sound system (link). It's 7.1, but not too powerful and a little cheap. Is there a better system out there (5.1 or 7.1) that costs under $200? I need something that has clear mids and highs and clear, but not overpowering, bass. Obviously, since I have a pretty slim budget, I'm not expecting a top-tier system, but I DO want to get my money's worth. Any suggestions?
  2. Tsen
    29 Apr 2006
    Okay, per advice of another thread, I'm going with Z5500's. They're hella expensive, but the additional quality and power should make it worth it. I'll have to pass on the sound card until next paycheck, or maybe longer depending on how big it is.
    So the question on the X-Fi Extreme Gamer vs. X-Fi Fatal1ty still stands, but the speakers are taken care of.
  3. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    It's entirely up to you/your budget.
    I personally have a 'Fatal1ty' edition of the card, and I'm very happy with it.
    But I know others who are running the standard Xtreme Gamer, and they're very happy with it.
    May I suggest, therefore... that you read a few reviews of each card... then decide which of the two is the one for you :idea:
  4. Aterius Gmork
    Aterius Gmork smell the ashes
    25 Sep 2007
    Both of them cannot be used with a microphone when used with a 7.1 system.
    Main difference are the 64mb RAM the Fatality has and the Xtreme Gamer not, adding some performance in games, giving you a few more frames. But when my brother wanted to get one of those I have read a few reviews, and I think the audio quality has been measured equal. So the question is - is the performance boost worth it?
    I am not sure, if I would go for a creative, or rather with another card. I have never actually listened to it, but the AuzenTech HDA X-Plosion 7.1 DTS Connect might be worth a look too.
  5. Hazardous
    21 Jan 2004
    I have! I have one in an older rig :D
    They make great cards... no doubt about it, so... although the HDA X-Plosion 7.1 DTS Connect might be a bit long in the tooth these days, it's still worth considering :thumb:
    The same goes for the [similarly long in the tooth] M-Audio 'Revolution' 5.1/7.1 cards :idea:
