Networks Spare server - suggestions?
Discussion in 'Hardware' started by J05H11E, 1 Sep 2010.
  1. J05H11E
    J05H11E Fujitsu Technical Analyst
    5 Aug 2010
    Evening Guys,
    Currently acquired a mini-itx rig, nothing special (2.10Ghz Dual Core, 2gb ram, 250 hdd) for which i have no use for.
    First I thought of using it as a HTPC, but it lacks hdmi :/
    I am currently using it as a sandbox/download box that I can connect to from work...
    Any idea what else i could use it for?... i want to keep it as some kind of server though due to its low power usage etc.
    /Discuss
  2. favst89
    favst89 What's a Dremel?
    23 Jul 2010
    If you are still interested in the possibility of a htpc then if it happens to have a graphics slot (atleast some itx do) you could use something cheap with hdmi like this.
    Another option could be a NAS box if you have lots of data to keep safe or multiple pc's in the house after the same data. You should still be able to access it remotely as well I believe.
  3. roosauce
    roosauce Looking for xmas projects??
    12 Feb 2010
    Windows home server? I don't know anyone running this, but it sounded pretty decent.
  4. Syn
    Syn ¯\(°_o)/¯
    4 Aug 2010
    Use it as a NAS box. Also what case is it in?
  5. saspro
    saspro IT monkey
    23 Apr 2009
    I run WHS it's great (once you work out how it works)
    I'd say either use it as a nas or firewall
  6. TomH
    TomH BELTALOWDA!
    28 Nov 2002
    Was gonna say, does the board have a PCI-E slot?
    Sounds a bit overkill for a NAS, but so long as it's got a Gigabit LAN port you should be able to get a decent bit of performance from it. Just be sure you need it before wasting the power. It's often better to split the bits, sell 'em in the market place and put the money towards upgrading something you will use. :)
    Look at something like FreeNAS or Openfiler for 'out of the box' NAS-centric operating systems.
  7. matt_lumley
    matt_lumley You're only supposed to...
    28 Apr 2010
    Ive aquired something similar and decided to use mine as a NASbox with freeNAS installed, runs like a dream and i have my laptop, sisters laptop, dads PC and mums laptop automatically backing up most nights :)
  8. Pookeyhead
    30 Jan 2004
    +1 on a NAS. You can never have enough NAStorage :)
  9. craigp84
    craigp84 What's a Dremel?
    28 Oct 2009
    Firewall with traffic shaping
    Caching nameserver
    Proxy server
    You could turbocharge your internet connection.
  10. cian1500ww
    cian1500ww Drunken Irish Dude
    30 Aug 2010
    Folding, no point in letting it go to waste :clap:
