Modding Speakers that power via Molex
Discussion in 'Modding' started by Noah, 5 Aug 2005.
  1. Noah
    Noah What's a Dremel?
    8 Feb 2004
    Do they exist?
    I need something as small as possible and one that is very powerful.
  2. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    yeah, there are crappy ones that can fit in a cd bay but they dont really sound good, I couldnt use them for music, only like windows sounds lol, but at a lan i guess they could be fine. And yeah, they run of a molex. Google is your friend :rock:
  3. Noah
    8 Feb 2004
    I can't find any. Link?
  4. tm36usa
    21 Jan 2004
  5. Noah
    8 Feb 2004
  6. tm36usa
    21 Jan 2004
    I wouldnt know, All tv's are different. Some crap korean tvs suck by the sharp 13" I have sounds good. They sound about as good as the ones in those cheap boomboxes that recive FM. Although there are some 50 dollar ones that accualy might sound good looking at their specs
    EDIT: These: http://www.mycableshop.com/sku/SPKINTPROBK.htm They even have a sub! :eeek:
  7. DrDing
    DrDing What's a Dremel?
    13 Jun 2005
    you can also think the speakers that come with lcd monitors...if you can manage to hook the lcd up to a molex then those speakers would in turn be powered by the molex.
  8. theurgy
    theurgy What's a Dremel?
    8 Oct 2004
  9. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    I'm assuming you're trying to cut down on power leads?
    You could try mains powered speakers that use a "T" style IEC connector.
    The plug has both male & female IEC connectors on it and the lead comes out
    of the middle. It fits between your PSU & power cord like this (crappy ASCII art)
    Code:
                    _____
         Power ->  |     | -> PSU
         cord       ¯¯|¯¯
                  Speakers
