SpeedFan CPU temps
Discussion in 'Hardware' started by mm91187, 22 Feb 2004.
  1. mm91187
    mm91187 What's a Dremel?
    17 Feb 2004
    I jsut installed SpeedFan to monitor my temps(MBM5 wouldnt work :wallbash: ) But it has 3 Temps and HD0.
    Temp1: 52 Celcius
    Temp2: 35Celcius
    HD0: 29 C
    Temp3: -1, -13, 23C (NOT STEADY AT ALL!)
    Which one is my CPU temp? The BIOS had my temperature at 37C last time I checked. Oh and by the way, any other Software to check the CPU tempuerature would be great of you could add
  2. SnipeHunter
    SnipeHunter What's a Dremel?
    20 Feb 2004
    Temp1: is your cpu temp Temp2: is your mobo temp HD0: is your hard drive temp.
    I dont know what the others are bcoz thay are the only three i have on my speedfan. Is it speedfan 4.09?
    :D
  3. mm91187
    17 Feb 2004
    are you sure Temp1 is my CPU temp? Cuase that cant be, i have my Volcano 12 at full blast and in BIOS it said it was around 32-37C. I heard on anohter forum taht Temp1 is your mobo, Temp2 COU, temp3 is your case....my CPU temp cant be 51C when im just on aim
  4. kenshin
    kenshin Banned
    22 Feb 2004
    this picture shows that speedfan/mobo sensors are far from reliable
  5. Xtrm2Matt
    Xtrm2Matt What's a Dremel?
    23 Jan 2004
    Temp 2 is my CPU Temperature on my SpeedFan? Temp 1 is my Case Temperature..
  6. Tim S
    Tim S OG
    8 Nov 2001
    youve not configured either speedfan or MBM correctly in that image.
  7. kenshin
    kenshin Banned
    22 Feb 2004
    If you are talking about MBM sensor 3, then i have configured it correctly. These are the readings it gives out 1) Winbond 3 (-105) 2)Winbond 3 2N3904 (127C) or 3) Winbond 3 diode ( -127C) . Which one is right? :worried: :hehe:
  8. Tim S
    Tim S OG
    8 Nov 2001
    depends on what motherboard you're talking about, because not all motherboards have 3 sensors.
  9. mm91187
    17 Feb 2004
    none of this helps? Temp2= cpu temp? temp1 = ???, temp3 = ???
  10. kenshin
    kenshin Banned
    22 Feb 2004
    Lowest temp= Case temp
    Medium temp= Northbridge temp
    Highest temp= Cpu temp (unless you are using phase cooling or tec's )
  11. El_JimBob
    El_JimBob Minimodder
    28 Dec 2003
    Ive used MBM, Speedfan and AIDA and each of them reports a diff temperature for Temp1, 2, 3, etc.
    Highest temp may not necessarily be CPU temp. Ive found hot air pockets in mates computers that edge over their CPU temps.
  12. SnipeHunter
    20 Feb 2004
    My temp1 is 64C and temp2 is 38C if temp2 is my cpu then what is temp one??
    do u know of any other good temp programs?
  13. TMM
    TMM Modder
    12 Jan 2004
    not really. My kt600 chipset is BURNING HOT at 170mhzFSB and i would say its hitting anywhere up 55oC at 200mhzFSB.
    my mobo reports the CPU @ 41 and system(northbridge) @ 30, BUT the northbridge heatsink is definatly MUCH hotter to touch that the CPU heatsink.
  14. Darv
    Darv Bling!!
    12 Aug 2002
    If you're running more than one monitoring software at a time they will interfere wiht each other and neither will show an accuarate reading.
    @ mm91187, if you want to get MBM to work have a look through their forums to find the correct settings for your board.
  15. simon w
    simon w What's a Dremel?
    3 Nov 2003
    I can happily run Asus Probe, Speedfan & MBM all at the same time and they'll all give the same temps
  16. cderalow
    cderalow bondage master!
    23 Jan 2002
    your northbridge chipset cooler is also a lot smaller than your cpu cooler.... this makes a huge difference in the actual dissipation of heat from it, and in the average temperature of the object
