Well. maybe some of you guy's have saw the case I have been working on. I think that case is a disaster because I can't do anything with it because it is a AT and its to small to make it an ATX . So I thinking to make a spider case but this wel be an ATX . I was thinking to cut out the sidepannel a web. Send you a pic when i have a pic of my idea. Keep you guy's informd.
Well now you have a idea of what i am planning to do on the sidepanel. So there is gona be a lot of cutting work
Well, i dont think my mod is going to be that beutifull, and i aint gona makeit from scrats, just gona mod an old case.
Very, very nice! Turned out better than I had envisioned...not that I had envisioned crap, just a different look. You do very nice mod work, congratulations on the final result! Did you Dremel that, or was it laser/waterjet cut? Either eay, looks uber-sweet!
G69T: Maybe you should start your own thread to show off your case. It is sweet, and you may just be showing it off to give Gizmo some inspiration, but it could be construed as a thread jack as well. Gizmo: I really like the concept drawing of the web. It has a vortex-like look to it with the twist you gave it. Very nice indeed.
Moved to Modding. As per the Must Read BEFORE Posting forum rules, plans and ideas belong in modding. Project Logs are for actual modding work done, written up and photographed as a worklog.
a spider modd? well...when hwupgrade forum get up....i give you the image of italian spider web modd!
