Scratch Build – Complete ⭐ [SPONSORED] MK3D by Forsberg Customs
Discussion in 'Project Logs' started by Forsberg Customs, 10 Feb 2019.
  1. Forsberg Customs
    Forsberg Customs Minimodder
    9 Jan 2018
    Time to start things up again after a little brake since my last build Spegel. This time im doing another scratch build but this time it will be as close as i can make it a 100% 3D-printed. The build is going to be a small case featuring an ITX motherboard and a smaller type of RTX 2060 from Asus called Pheonix. I will continue to post updates on this project in the coming weeks so stay tuned for more and feel free to comment and send PMs.
    Specifications:
    PSU: Silverstone SX650-G ( Sponsored by Silverstone )
    Motherboard: Asus Z370-I
    CPU: Intel i5 8400
    Memory: Team Group Nighthawk 2x8gb ( Sponsored by Team Group )
    Storage: Kingston A1000 480gb M.2 SSD
    GPU: Asus RTX 2060 PHOENIX ( Sponsored by Asus )
    Fans: 2st Silverstone FM182 180mm ( Sponsored by Silverstone )
    Cooling CPU: Cryorig C7 ( maybe the Cu variant )
  2. Forsberg Customs
    9 Jan 2018
    Update!
    So it has been a couple of weeks since the last update and i have made some progress during this time and i have gotten all the components for the build aswell.
    As you can see i have started to put together the first version of the case to see if all the measurements lined up etc and there was some minor misses that i corrected in the cad later on but it was mostly fine.
    I have started to print the final version of the parts so in the next update you will see that and perhaps some cable making.
    As always, if you have any question feel free to ask me either in a DM or in the comments.
    Thanks to my sponsors for making this possible
    ASUS
    TeamGroup - Global
    Silver Stone
  3. Forsberg Customs
    9 Jan 2018
    Mini update!
    Todays project was to get the cables for the fans sleeved since the ketchup and mustard cables wasnt doing it for me.
    These fans has two additional wires coming from the hub which are use to connect the included fan controller. Since im not going to use those or the included jumper for the connector i cut them off and jumped the connections on the hub instead to minimize wires.
    I have more stuff to show in the coming weeks so stay tuned :)
    neSSa likes this.
  4. kim
    kim hardware addict
    10 Jan 2016
    it's taking shape nicely...I like this design :thumb:
  5. Forsberg Customs
    9 Jan 2018
    Thanks Kim! :D
  6. Forsberg Customs
    9 Jan 2018
    Update!
    After i sleeved the cables for the fans i decided to make some covers for the back of the fans instead of the stickers.
    Next the GPU shroud and fan needed a makeover to fit the theme of the build. I think it turned out quite nice, what do you guys think ?
    I also decided to delid my i5 8400 to improve thermals and noise. Im well aware that the CPU is locked and this was done only to improve temps and noise since the GPU is mounted so close to the CPU cooler. The temps dropped from 84-85C to 64-65C in Aida64 after 20min.
    Cya!
    kim likes this.
  7. Forsberg Customs
    9 Jan 2018
    Update!
    Time for the next to last update for this project. Im currently doing the cables for the build which is basically the last thing to do.
    Since the last update a couple of things has happend. All of the parts have been painted and in the end i went with a copper base with a white crackle paint on top and it looks really good :). The LEDs and power button has now been mounted aswell.
    Next update will be the finished build! [​IMG]
  8. Forsberg Customs
    9 Jan 2018
  9. Forsberg Customs
    9 Jan 2018
  10. kim
    kim hardware addict
    10 Jan 2016
    woah...there are many fresh brand new ideas here...:dremel:, the color sheme is very nice and the sleeving of the PSU is absolutely lovely :clap:
  11. Forsberg Customs
    9 Jan 2018
    Well thank you Kim!
  12. hayate89
    hayate89 What's a Dremel?
    19 Nov 2015
    3d printer used?
  13. Forsberg Customs
    9 Jan 2018
    Im using the Prusa i3 MK3
  14. 1pq-Lamz
    1pq-Lamz What's a Dremel?
    16 May 2019
    What method did you use to get that cracked paint effect?
  15. Forsberg Customs
    9 Jan 2018
    There is a paint from Montana Gold which is called "crackle" that i used for the effect :)
  16. Cheapskate
    13 May 2007
    :lol: ALL my paint work looks like that.
    -Just kidding. It's looking great.
  17. Forsberg Customs
    9 Jan 2018
    Hehe thanks :D
  18. Forsberg Customs
    9 Jan 2018
    This will be the last update before the final pictures [​IMG]:)! These are some pictures taking during the last part of the cable management!
  19. Forsberg Customs
    9 Jan 2018
    Time for the final pictures! I hope this project has been interesting to follow because its been a blast to build. This was my first but not last project involving my 3d-printer so stay tuned for cool stuff in the future. This build be exhibited at Birdie LAN in Uppsala Sweden so if you are going to attend come by and say hi.
    arduum likes this.
  20. 1pq-Lamz
    16 May 2019
    Honestly, those 3d printed parts looks way too good coming out from a fdm printer. Did you sand all the parts before painting? If so I can imagine the time you spend with sanding. Did notice you skiped outosanding with the logo print xD. And lastly some questions about the print settings.
    Layer height? Ironing? Coasting? Sanding method? Sorry for all the questions but im really curious, post processing of 3d print always takes most time.
