Modding Spraypaint Question
Discussion in 'Modding' started by Dr_kazza, 2 Sep 2003.
  1. Dr_kazza
    Dr_kazza What's a Dremel?
    2 Nov 2001
    Has anyone spraypainted plexi so that it is partially see-thru?
    A bit like the window tint effect but spray paint would allow for curved surfaces...?
  2. Cowinacape
    Cowinacape What's a Dremel?
    26 May 2003
    They do make clear paints, generally available in craft shops. How good of a stick it would have to super smooth plexi I don't know, have you considered the idea of perhaps using window tinting film instead? Might be a bit easier.
  3. Dr_kazza
    2 Nov 2001
    used the window tint but it's VERY difficult to do on a curved surface... you need to cut out little bits.
    Imagine window tinting something shaped like a fruit bowl... that's the sort of idea I had.
  4. Cowinacape
    26 May 2003
    Yeah i see where you are going now, i am not going to be of much help to you other than to possibly recomend, coloured acrylic ( I am thinking of pre cast coloured sheets here now). but yeah trying to wrap the tinting around a bowl shape would be tough to say the least.
  5. :: kna ::
    :: kna :: POCOYO! Moderator
    15 Mar 2001
    Glass spray paint should do it... I've used it on clear acrylic before.
  6. Dr_kazza
    2 Nov 2001
    oooh that sounds like the ticket... are we talking car parts or art supplies?
  7. :: kna ::
    15 Mar 2001
    Art supplies.. Plastikote do something like it, but anything similar will do. I'll try and find a link.
  8. Dr_kazza
    2 Nov 2001
    leg end thx.
    all i gotta do is find the perspex sphere... hamster ball anyone ;)
