Storage SSD's-Boot or Cache? Help!
Discussion in 'Hardware' started by mikeyandrewb, 12 Nov 2011.
  1. mikeyandrewb
    mikeyandrewb What's a Dremel?
    31 Oct 2011
    Hi all,
    I am building a PC and wondered about using an SSD to speed things up. I will post a full spec list later on when I have finalized everything but I wondered about using an SSD.
    Should I install Windows on an SSD when I build, or use Intel's SSD Caching(Smart Response Technology)?
    I could always install the SSD as a Cache later if I wanted too, but if I wanted to install Windows in the first place I would have to do it during build. I will also be getting a Samsung SpinPoint F3 1TB to store everything else.
    Also what size SSD would I need? Would a 64GB do or would I need bigger?
    http://www.anandtech.com/show/4329/intel-z68-chipset-smart-response-technology-ssd-caching-review/2
    Any Suggestions?
    Many Thanks
    Mike :D
  2. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    Boot. Crucial 64GB M4.
  3. meandmymouth
    meandmymouth Multimodder
    15 Sep 2009
    What is your budget?
  4. rob the bank
    rob the bank What's a Dremel?
    13 Mar 2010
    Main thing about Intel's SSD Caching is that its designed to save money buy allowing you to use a 20, 40 or 60gb SSD paired with your large drive.
    So if you can afford a SSD that’s big enough to use as your main drive, then do that, as it will be faster.
    If not getting a cheap but fast say 40gb SSD will allow you to get close to full SSD performance but at less money (depending on how big an SSD you would of needed).
  5. mikeyandrewb
    31 Oct 2011
    Ok,
    Thanks for the response. I will not have enough money for a full sized SSD but as a 64GB one is only around £70 I could get one of those. I could squeeze a Windows install onto the 64GB but I would have to migrate all the libraries to the HDD. Which sort of defeats the point. With the SSD Caching I could keep all the Windows Stuff on the HDD and accelerate everything else.
    Thanks
    Mike
  6. halcyondays
    halcyondays What's a Dremel?
    10 May 2010
    When I built my rig, using a 40Gb SSD (hate being an early adopter) I installed the key windows files on the SSD and then used an unattend.xml file to customise the install and put the \users folder on a HDD partition. I also and 2 other partitions on the HDD for 32 and 64 bit programs and created a mount to these under the program files(x86) and program files directories, so bigger installs I just put into program files\hdd rather than just program files. works well and stops the ssd swelling in size other than from patches
  7. Madness_3d
    Madness_3d Bit-Tech/Asus OC Winner
    26 Apr 2009
    Have main OS on 64GB drive, with office, bits and bobs and a few games. Would say it's fine, especially if you get friendly with Directory Junctions...
