so the idea is to make a part of the stargate in 1:1 relationship for the real thing materials would be wood / mdf and so on some of the work is allready done some of it is in planning i have got some pic's will post 'em later comments ?
http://img14.imageshack.us/my.php?image=kumbd1mo.jpg B was the original idea A is as it is now dimentions http://www.estonia.ca/~v2hja/Clipboard0222222222.jpg http://www.estonia.ca/~v2hja/mod/case/gate.jpg after original cut (6 of those were cut) http://www.estonia.ca/~v2hja/gate_6.jpg 2 sidest put up and little photoshop xtra next a frame was desinged http://www.estonia.ca/~v2hja/kasti_raam.jpg http://www.estonia.ca/~v2hja/kasti_raam_3.jpg as of now it is 18kg i have collection of pictures of the stargate but any new pic's are wellcome
interesting idea, when you said one part of the gate, i thought you mean one symbol section. this should be an interesting mod
Hmm... How bout' making a base for the portal (something like this http://www.vargr.com/pages/renders/images/StarGate.jpg), and stuff the hardware down there, then you can make like a 1:10 scale of the whole portal on top. Fill it with some LED's or CCFL's and you be on and poppin'
heh, v2hja lõpuks teeb oma modi ... Keep it up ! this should be interessting, ill keep an eye on this
A full sized Stargate would be approx 20ft (6m+) diameter. We had a half-scale one at some Stargate conventions I worked at a few years ago. crappy pic here
a full size stargate would be 4.52m the outside diameter and 3.5m from the inside dimentsion the gate itself shoud be 0.5m thick http://www.estonia.ca/~v2hja/how_this_info_was_obtained.jpg and she is about 1.76m tall ....... and she ise quite next to the gate ^^ now back to the drawingboard calculating materials needed next http://www.estonia.ca/~v2hja/tray_2.jpg next step would be mdf plate for this mobo tray btw Goth kle jah kunagi peab ju kah ise selle lolluse ära tegema EDIT: frame vs. mobo tray http://www.estonia.ca/~v2hja/gate_8.jpg
I love the Stargate show. but you may want to read this before you post an update: http://forums.bit-tech.net/showthread.php?t=46310
Question: Is the outer plating going to be curved, like a 'pie-slice' outta the gate? I'm only asking cuz the frame looks completely straight.
sorry this mod is going to be on hold for a while the frame itself got cracks in it and bended by itself
