Build Advice Starting a build, would like advice...
Discussion in 'Hardware' started by voids sleet, 29 Apr 2012.
  1. voids sleet
    voids sleet What's a Dremel?
    3 Sep 2009
    Hello there, its been a good 2 years since i did anything to my pc (other then install 7) and now ive decided that i need a whole new pc.
    now ive got a basic thunk of where to start but ive thought i best come get advice before i start...
    so the basic idea i have is i'd love to go sli / crossfire, try for full bandwith on 2x of the pci-e for that.
    on that which chip should i go for, not a intel or amd fan boy so it makes no difference to me either one as long as it does what it says on the tin.
    so i guess the mobo would follow on with them 2, not planning on ocing the chip / gpu but a bit of head room may be good.
    ive not set my self a budget yet but in the long run i dont want to be spending so much i need to leave a leg as a deposit but i am open to options
    I already have a haf x sat here waiting to get filled.
    right best keep looking at things, what would your advice be with all this :worried:
  2. echo three
    echo three What's a Dremel?
    26 Jan 2012
    What do you play and at what monitor res?
  3. voids sleet
    3 Sep 2009
    ive got a 1920x1200 monitor at the moment, im considering changing it but will see
    I play so many things, ive got 48 games in my steam and another 20+ on the wall so kind of hard to narrow it down :thumb:
    shooters and rpgs are mainly what i play, that should narrow it down some
  4. mikeyman198
    mikeyman198 Lets pretend this is hilarious.
    12 May 2011
    If you want SLI/CrossFireX then Intel Ivy Bridge is the way to go due to the PCIe 3.0 lanes.
    Here is a core build for you: http://www.scan.co.uk/savedbasket/83f8b74aea5841f9a025ea9361fb39fe
    Obviously you may not want a 680, and can wait to see what the rest of Kepler has to offer, and you can save money in other places, but this is just an idea :)
  5. voids sleet
    3 Sep 2009
    That build looks sound thanks, what I think I'll do is that mobo, chip and 2x the ram then wait a month or 3 like you say and see what's what with Kepler...
    Failing that 2x of the 680 is a lot more powerful then a single 295
  6. mikeyman198
    12 May 2011
    It would be indeed, although at 1200p You wouldn't really need two, not until 1440/1600p.
  7. voids sleet
    3 Sep 2009
    I have been considering the 27" dell for a while, I'd be aiming for one of them after this just so it is not a waste
    Plus it'll help some with my editing of my photos, 2 good reasons to go get one
  8. Teelzebub
    27 Nov 2009
    The Dell 27" is a excellent choice of screens and now the prices have come down makes them even better
  9. voids sleet
    3 Sep 2009
    Yeah I started to look at the dells when they were like £700+ now there coming to the £500 mark it's tempting
