starting problem with a dell
Discussion in 'Tech Support' started by mongoze, 1 Feb 2008.
  1. mongoze
    mongoze I have a Dremel
    3 Jan 2008
    I have a problem with my brother's pc. we had a power cut and when the he started the pc nothing happened the power button just blinks yellow.
    it seems like PSU won't start, but indicator on the mobo is lighting up when I connect the power, but that's it
    is it the PSU or mobo that the problem?
    is there any way of cheking the PSU? I read somewhere that if connect the green and grey wire the fan on the PSU will start.
    I appriciat all help.
  2. mongoze
    3 Jan 2008
    the pc is a dell deminsion 8300.
    PSU: macron 400W
    mobo: originale
    CPU: P4 2,8GHz
  3. Thacrudd
    Thacrudd Where's the any key?!?
    27 Oct 2006
    onhook the ATX connector from the mobo. Bridge the green wire to the brown wire directly to the left of it. Plug the power supply into the wall and turn it on. If the power supply comes on then it is OK.
    PSU TEST GUIDE
    I hope that helps
    If you do that to a spare PSU you can use it to hook up lights and fans around your room. lol
  4. Krikkit
    21 Jan 2003
    Even if the PSU does start, it's no guarantee that it works properly.
    Oh, and pretty much the best method is a paperclip, stick it in the plugs on the ATX connector (bottom side, the one normally facing the mobo). :)
  5. baron02
    baron02 What's a Dremel?
    28 Mar 2005
    If you get a amber flashing light on the power button of a dell, It does indicate that there is a problem with the Power supply unit
  6. mongoze
    3 Jan 2008
    I tried connecting the green and the black wire as thacrudd said, but it's still dead.
    so now I have to buy a new PSU or can I repair it in anyway?
    it's no problem if it takes a little expertice/hard work to repair, I'll handle it.
  7. phillj
    phillj What's a Dremel?
    18 Jul 2007
    Hi Guys,
    It might be worth giving Dell a call if it is still under warrenty as they should replace it for free. Worth a try
  8. mongoze
    3 Jan 2008
    the warranty is out and I have changed the PSU(it's not stock). so they won't help me.
  9. mongoze
    3 Jan 2008
    anyone who know where I can get a wiring diagram of my PSU? I think I've found the number of wiring plate.
  10. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    Well, read your signature :p
    I think it will be hard to find and wiring diagram. Even if you do find it, switch mode PSUs are hopeless to work with.
    By best recommendation would be to just bin it, and get a new PSU.
