Starting slow upgrade for next year...
Discussion in 'Hardware' started by tintin, 21 Apr 2006.
  1. tintin
    tintin What's a Dremel?
    6 Jul 2004
    I'm starting to 'compile' my new pc in the next few months with a view to completing it after Christmas with vista, Conroe et all available.
    I'm just looking at cases now but i'm wondering is there any particular thing I should be looking out for with Conroe, vista, directx10 even a RAID array setup that I'll need in the case? In other words, i was looking at the new Antec Sonata II case, which looks nice but only has a 450W generic PSU inbuilt. Can anyone offer any good cases I am not really interested in water-cooling but a good quietish case with good cooling?
    sorry for the long windedness of the post
  2. ashikamlani
    ashikamlani What's a Dremel?
    11 Mar 2006
    antec p180?
  3. McKaamos
    McKaamos What's a Dremel?
    12 Feb 2006
    Definately an Antec P180, or a Coolermaster Stacker.
  4. tintin
    6 Jul 2004
    yeah i was actually looking at this - seems to be getting good reviews once your not looking for water cooling - which i'm not but apparently there can be issues wire management with the motherboard facing upwards i.e. away from the PSU
    Does anyone have any experience with the antec P180 or the Coolermaster stacker?
  5. ashikamlani
    11 Mar 2006
    all i know is that the p180 has a realy wierd layout to help with cooling, so if u are an inexperienced builder then you should stay away from it.
  6. tintin
    6 Jul 2004
    i am fairly inexperienced alright built one in college a few years ago but it was a basic system...i wouldnt mind if i t took me a while to find my way around the case but as you said it could be more hassle than its worth.
    If there are better options elsewhere i'm looking for advise!!!
    p.s. the coolermaster stacker doesnt look like it would fit in my house haha!!
  7. MiNiMaL_FuSS
    MiNiMaL_FuSS ƬӇЄƦЄ ƁЄ ƇƠƜƧ ӇЄƦЄ.
    24 Dec 2003
    p180 is the best case there is IMO, beatifully quiet.
    Couple if with a decent silent cpu cooler and a silent gpu cooler and u got a silent system (fans provided for the case are very good, and as long as u dont buy a maxtor hdd u wont hear a thing).
    The only problem with it is with some PSUs with shorter wires as the psu is at the bottom of the case...but as ur buying a nu system i imagine u'll be getting a decent brand psu anyway, most of which are unaffected by such problems.
  8. hitman012
    hitman012 Minimodder
    6 May 2005
    It won't be generic - Antec only package their own quality supplies with their cases. That particular unit will be more than enough to power most systems.
    Don't you mean a WD? ;)
  9. tintin
    6 Jul 2004
    point taken about the 450W antec but i'm steering towards the P180 now that way i'm can go with a major PSU that 'should' last me a few upgrades.
    any opinions on the P180 or similar cases?
  10. nimbu
    nimbu Multimodder
    28 Nov 2002
    I have the P180, and other then the stupid vga / pci cooler thingy, its an awesome case.
    Wiring can take a little while to get sorted hence I would def recommend a modular power supply. Also as stated with the PSU being under the board some of the cables may not read, but they are easily extendable.
    CM Stackers are ok, but having to buy the extra 3.5" rails for disks can be a little off putting, alsi I find the front bay covers a royal pain to get aligned up. On little bang and I found they often fell back in.
    Hope that helps,
    Nims
  11. tintin
    6 Jul 2004
    pardon my ignorance but whats a 'modular' power supply? is it when the cables arent attached to the PSU?
    actually what psu are you using with yours? do you have an issues with the built-in fans? i heard they can get a bit noisy at times
  12. ashikamlani
    11 Mar 2006
    yes, a modular psu is one where you can disconnect the cables that are not currectly being used from the psu box itself. This saves space and makes cable tidying much easier and more simple. You do not have to hide unused cables, you can just remove them :D
  13. tintin
    6 Jul 2004
    seeing good review for the Enermax Liberty 620W modular but people seem to have a few issues with other modular psu's for whatever reason
  14. ashikamlani
    11 Mar 2006
    i myself have never heard of issues with just modular psu's. Btw, the enermax is a very good psu, if not a bit pricey.
  15. nimbu
    nimbu Multimodder
    28 Nov 2002
    "!pardon my ignorance but whats a 'modular' power supply? is it when the cables arent attached to the PSU?!
    Spot on
    I have the Antec Newpower modular PSU. I did read somewhere about this psu having some issues with certain asus motherboards, but so far has been working fine with the following spec.
    Opt 146 @2.7Ghz, Asus A8N SLI Delux, 6800 Gt, 2x WD 37GB raptors, 400GB HD and Optical Drive.
    As for cabling the rig, I got all the bits into the case with the wires just there. Got windows up and running hows i like it. Then stripped out the cabling and tidied it all up.
    "i heard they can get a bit noisy at times"
    Thats personal preference, with them all on at low I can still here my chipset fan over them.
  16. tintin
    6 Jul 2004
    are all of the antec PSU's modular? What is the different between the truepower and smartpower models?
    p.s. what WATT is your Antec Newpower modular PSU?
    thanks for the reply
  17. holiver
    holiver What's a Dremel?
    21 Apr 2006
    I just moved all my bits and bobs from an Antec SLK 3000B to a Gigabyte Aurora. The Antec is a fantastic case for the price if you want quietness along with good cooling but I moved to the Gigabyte to improve on both of these and for more style. The only criticism I have of the Gigabyte is that because it is lighter it makes the hard drive seeks and reading louder but apart from that it's much better.
  18. nimbu
    nimbu Multimodder
    28 Nov 2002
    As far as I know not all antecs are modular.
    http://www.antec.com/uk/productDetails.php?ProdID=05481
    thats the psu I have.
