Static and electrostaticity
Discussion in 'Hardware' started by wilkyboy, 12 Sep 2007.
  1. wyx087
    wyx087 Multimodder
    15 Aug 2007
    another quick question:
    if i don't bother earth myself, can i still pick up CPU's and graphics cards by their non-conducting edges?
  2. xion
    xion Minimodder
    23 Aug 2006
    Had a friend who was convinced he'd fried his mobo due to the static generated by using a vaccumm in his case... didn't take me long to locate the problem, he's sucked a couple of cap's clean off the board! :grin:
  3. Moriquendi
    Moriquendi Bit Tech Biker
    3 Nov 2005
    Yeah you can, bear in mind that things like the heatsink and bracket will be electrically connected to the cards earth and so static COULD fry something, having said that I do pick things up by the heatsink, particularly motherboards and Ive never fried anything.
    Moriquendi
  4. mushky
    mushky gimme snails
    24 Mar 2003
    Those wristbands are more likely to cause damage by catching something on the curly cord and knocking it off the table.
    I've never killed anything and I'm far from careful about static. Coincidentaly I was hoovering out my pc case last night, I was running the attachments over everything in there, it's all fine.
  5. Daniel114
    Daniel114 What's a Dremel?
    9 Sep 2007
    So how did it go today? Any nasty surprises?
  6. benny269
    benny269 What's a Dremel?
    13 Sep 2007
    Its your first build so you're a little apprehensive but don't worry about it. Just keep everything simple.
    Touch the case after plugging in PSU to ground.
    Magnetic screwdriver probably won't damage anything, but its not that important anyway. Just use a standard screwdriver, spend 5 mins more and don't think about it again.
