Steam Steam Beta Error
Discussion in 'Gaming' started by PBear23, 23 Apr 2010.
  1. PBear23
    PBear23 What's a Dremel?
    4 Feb 2009
    Hi Guys,
    Installed the new Steam UI a couple of days ago, and it was working great, completed MW2 again.
    However when I start it up today i get an error that it cannot connect to steam network, try again later. THis has happened all day so far, so I can't use steam.
    Is anyone else having problems?? or no a solution???
  2. curck
    curck What's a Dremel?
    23 Apr 2010
    Same problem here.
    Tried with removing 'Clientregistry.blob' but that didn't work either.
  3. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    same here i truely hope this does not continue all night
    edit
    i have been a supporter of steam for some time now this is the first time it has crapped out on me but i really want to play global agenda after a hard week at work
  4. yakyb
    10 Oct 2006
    found a fix just run steam from command line with -clearbeta added on
  5. maximus09
    maximus09 Forever n00b
    8 Jun 2009
    I had a problem with the official release version of the update. After the update and restart it said "Fatal Error: Program can't load modules" or something to that effect.
    You can check on steam forum for solution. It involves renaming the steamapps folder, restarting steam which will create another one, copying a file across to the old one, delete the newly generated steamapps folder and rename the old one back to steamapps.
    There is another solution to delete a DLL files and restart steam to download it again.
