Storage Storage server
Discussion in 'Hardware' started by Armand-[79th], 14 Oct 2008.
  1. Armand-[79th]
    Armand-[79th] Vintage modder
    19 Jan 2004
    I'm putting together a storage server based around an old QDI Legend board, BrillianX IV with 2x P2-400s, 512MB PC133 and as many SCSI HDs as I can plug in. ;)
    I should be able to upgrade the CPUs at some point, as the board will take P3-500s @ 100FSB.
    What I need to kick off this project, is some suggestions on a good E-ATX case and decent power supply.
    I don't need a full on SATA/PCI-E PSU, but I do need to power at least 4 internal HDs and maybe 2 DVD-RWs.
    Money is a limiting factor, so cheaper is better but I don't intend on buying any old rubbish..
    Any constructive input will be appreciated. ^_^
  2. Armand-[79th]
    19 Jan 2004
  3. Splynncryth
    Splynncryth 0x665E3FF6,0x46CC,...
    31 Dec 2002
    you might get some info on that case from this thread: http://forums.bit-tech.net/showthread.php?t=153827
    The biard uses an extra power connector like the ATX 12 that is commonly used now. This was a competitor. I don't remember what it was called, but finding a PSU that supports it could be hard.
  4. markjw
    markjw What's a Dremel?
    4 Aug 2007
    as an alternate thought why not consider buying a used server - something along the lines of a Dell Poweredge 2500.
    One here on eBay for £60.00 - http://cgi.ebay.co.uk/Dell-PowerEdge-2500-Dual-Processor-Server_W0QQitemZ110301671275QQcmdZViewItem?hash=item110301671275&_trkparms=72%3A1301|39%3A1|66%3A2|65%3A12|240%3A1318&_trksid=p3286.c0.m14
    Mark
  5. Armand-[79th]
    19 Jan 2004
    Splynncryth: Nice thread ;) As for the extra power connector, I have fired up the board already with a standard 20-pin ATX PSU so I'm reasonably confident it should work with a modern PSU. If not, I'll look at modding the new PSU. :)
    markjw: That is a good purchase, but sadly it would take too long for me to get money onto paypal and I can't collect it. Besides, you can't beat building it yourself. ^_^
  6. Armand-[79th]
    19 Jan 2004
    Splynncryth: A quick RTFM reveals the following;
    Assistant Power Connector is an optional connector.
    If there is too many peripheral devices in your system, a power supply with this assistant power output is recommended to be used.
    I'll only be using the basic kit to get this up and running, so I don't think it's going to be an issue. :)
    Also, major delays in raising the cash.. so it's going to be a while until I can order that case.
    I'll probably end up having to wait until I get a proper job. >_<
  7. Splynncryth
    31 Dec 2002
    OK, that connector was the 'competition' to the now standard 4 pin 12V ATX connector IIRC. So it's good to know it's optional.
    Proper jobs are overrated, I have one now and still don't have enough cash :)
  8. Armand-[79th]
    19 Jan 2004
    Ok, it's been a while.. but I have been slightly pre-occupied with various RL issues.
    Especially getting serious with my jobsearch, now I have a girlfriend. :)
    It's not easy when you've been out of work for 5 years. ¬_¬
    I'm going to push this particular board into long-term storage.. as I now have a better board, which was kindly donated by a member of PClincs as a kind-of birthday present. ^_^
    It's a dual socket370 board with 2x P3-800EB. :D
    I'll dig up all the other details later but fair to say.. it's a far superior board, aswell as being standard ATX. YAY \o/
    I have a couple of old ATX cases awaiting a good mod, so I'll have to start making plans for them.
  9. Glider
    Glider /dev/null
    2 Aug 2005
    If you just want a NAS, get a low power (~P3 600 ish) system, throw a Linux distro and a gigabit NIC on it and you are set.
  10. Nexxo
    23 Oct 2001
    As this server will presumably be running 24/7, low power consumption and low noise are key. Those old Pentiums III 800EB may seem like a bargain but they take a lot of juice -- 20.8 Watts each. Add to that the motherboard itself and you're looking at 60 Watts already -- without the drives. Get a Via Epia SN 10000series instead, or else an Intel Atom (you can get a dual core now). they use no more than about 20 Watts. Install FreeNAS, slap in some low power WD10EACS drives (3.8 to 8 Watts each). Cheap to build, cheap to run, quiet.
  11. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    My dual P3 doesn't draw much over 50w once its running thats with two HD's and a gigabit network card, and you have the option of doing some actual processing on them. I generally use it for compiling stuff since it on all night any way.
    They are still much more powerful than a epia and you more head room of you want to do some thing else on them or some expansion, run a small web server or a game server since the machine is on any way it doesn't hurt
  12. koola
    koola Minimodder
    11 Jul 2004
    The 1.86 GHz Dual Core Atom is better than duel P3's with a TDP of about 8W (circa 3.8W each core). The hard part is finding a Intel motherboard without the crazy 20W TDP chipset with GMA950 onboard. Stupid Intel.
    As for a OS, I vote for ebox.
  13. Armand-[79th]
    19 Jan 2004
    You all assume I'm paying the bills.. ;)
    Nexxo: I don't really do 24/7, that's just wasteful. Oh, and noise is never an issue.. unless it sounds like Concorde taking off. ¬_¬
    All good advice though..
    I mean, sure, it would be nice to buy some brand new kit.. but I really don't have the money.
    I even had to cancel on buying the case as I'm totally skinted out.
    Besides, I like messing around with older stuff.. as I don't have to worry about software issues or additional hardware that doesn't work with my OS.. blah, blah, blah. :p
    As for the drives, I've got a Sun 7/11 box with a load of SCA drives to pick from.
    I'm also getting a set of SAS drives, dunno what machine I'll drop those into though.
