Case Mod - In Progress Striker Wood
Discussion in 'Project Logs' started by twister7800gtx, 29 Oct 2019.
  1. twister7800gtx
    twister7800gtx Active Member
    2 Nov 2011
    Striker_Wood
    Let's strart with something completely new with materials never used before! Stay tuned!
    Hardware:
    Case: Antec Striker
    CPU: Intel Core i9-9900KF
    Motherboard: Asus ROG Strix Z390i
    GPU: Asus ROG Strix RTX 2080Ti
    Ram: Kingston HyperX 16GB
    SSD: Kingston 512GB
    PSU: Antec HCG X1000
    Cooling: Full Custom EK Water Blocks
  2. twister7800gtx
    2 Nov 2011
    Let's start right away with unboxing and a view of Antec's beautiful Striker.
    So immediately I show you the first component from which the mod takes its name: real laminated wood sheets! That we will use to “wrap” the outer covering and then pass it under the laser engraver.
    Stay connected for the next updates!​
  3. Mizuwari
    Mizuwari In vino veritas
    19 Sep 2018
    Looks wood ! No... good ! No... Let's say : very GWood ! :clap:
  4. Tech Cave
    Tech Cave Member
    18 Sep 2019
    I saw at Lucca Comics, really nice job Daniel!
  5. twister7800gtx
    2 Nov 2011
    Greetings guys!
    After a break for "work in progress at Twister Mod" we start again with a nice view of the main components of our mod. The photo is missing the ROG Strix 2080Ti but the heart of our version of the Antec Striker is already clearly visible and you can get an idea of the finished work.
    After applying the layer of wood and the necessary laser engravings, we move on to using the second new material: carbon.
    Considering the need to not distort the geometry of the case, we turned to the details to make this small case more particular than it already is.
    We have in fact opted for real carbon tubes which will "cover" the pre-existing frame structure, thus creating a stark contrast to the tubes which, instead, will be applied in the custom loop.
    That said, we proceed with the installation of the small but bad ROG Strix Z390i with its PCI riser cable and the first part of the custom loop.
    Stay tuned!​
    Jean R built and Mizuwari like this.
  6. Mizuwari
    19 Sep 2018
    Nice to have you back on this one! BTW, what kind of glue did you use for the wood?
  7. twister7800gtx
    2 Nov 2011
    thanks :D
    I use the new crocodile :) is very strong
  8. frack
    frack Member
    28 Feb 2020
    does the "wooden stile wrapper" is made for PC purposes?
  9. Jangalit
    Jangalit Member
    28 Feb 2020
    very good! will it keep though with heat and time?
  10. twister7800gtx
    2 Nov 2011
    Goooood evening guys!
    It's time for a brief update for the small Striker Wood! Given the relative simplicity of the mod, the worklog is already running out and now we show you a quick preview of the components that will be included in the system: In addition to the ROG Strix z390-I and the excellent RTX 2070 Super, we will use the new Antec Prizm kit as a fan unit to be installed in the rear of the case, to then complete everything with the usual custom loop with EK Water Blocks components and the HyperX Fury RAM to give an additional touch of light to the whole Mod.
    For perfect match the whole color scheme we choose some green coolant for the loop. Nice look with leds on uh?
    See you next week for the last update and the final shots!​
    neSSa and Cheapskate like this.
  11. twister7800gtx
    2 Nov 2011
    HI! no it's real wood sheets made for forniture purposes or modeling.
    I hope! Just joke: this glue has an operative temperature ranging from -50°C to +80°C so i think there's no problem. For time lasting i think that only time can answer but it's a very strong ad reliable glue. ;)
