strong and small psu's?
Discussion in 'Hardware' started by turbahn, 13 May 2003.
  1. turbahn
    turbahn What's a Dremel?
    29 Apr 2003
    I found a small psu for the seethrough case i'm building, but its only 200 Watt which is not enough... i need at least 300 Watt
    Does anyone know of an extra small 300W+ psu?
    thx in advance,
    Itai
  2. mushky
    mushky gimme snails
    24 Mar 2003
    dell make some small psu's but they would be expensive unless you can pick one up second hand.
    you could take a normal psu out of its case to reduce the size, but be careful in there man :p
  3. Kevo
    Kevo 426F6C6C6F636B7300
    9 Sep 2001
    You *could* get a 1U psu but anything above 300watt is very expensive.
  4. turbahn
    29 Apr 2003
    how expensive?
  5. star882
    star882 What's a Dremel?
    19 Mar 2003
    The Dell PSU I have is the same size as a normal ATX PSU.
    If you're talking about the PSU out of the case, Dell PSUs are actually larger than the average 250w ATX PSU(due to large caps, big and heavy heatsinks, and many control boards).
