Stupid computer
Discussion in 'Hardware' started by vivid, 25 Oct 2001.
  1. vivid
    vivid down in fraggle rock
    24 Sep 2001
    i need some help please but i dony know exactly what could be wrong, well here it is: whenever i go to play a game, like cs, tony hawks, spiderman any game like that ma computer will run fine for maybe 10 minutes and then it will either just close the game down and go to the desktop ot restart my computer
    computer spec : Tbird 850 @ 1gig, 256md pc133 sdram, matrox milenium G450 32mb gfx card 300W psu
    any help would be greatly apreciated thnx all
  2. RTT
    RTT #parp
    12 Mar 2001
    sure that 300w PSU is up to the job? thouhgt u had a 250w in it?
  3. vivid
    24 Sep 2001
    i changed it , i got the 300W from my crappy k62 machine and put it in the Tbird machine
  4. RTT
    RTT #parp
    12 Mar 2001
    well the 300 should handle the rig youve got there, unlikely that it wouldnt.
    what drives are in it?
    might be a software error somewhere? maybe gfx drivers seeing as its ALL games with same problem?
  5. vivid
    24 Sep 2001
    well i just loaded the latest G450 drivers after what you just said, but still i get the same problem :(
  6. Kevo
    Kevo 426F6C6C6F636B7300
    9 Sep 2001
    reinstall Windows
  7. vivid
    24 Sep 2001
    well i think that is what has caused the prob
    i formatted my hdd a while ago and everything worked fine, but ever since its been formatted i have been getting these problems
  8. Phil
    Phil What's a Dremel?
    19 Jul 2001
    er, that sounds like a CLASSIC case of overheating !!
    after ten mins the GPU and CPU heat up, and when they get too hot they can't handle what's being thrown at them anymore and the prog running crashes.
    Sounds more like a GPU overheat to me....what gfx card is in there ?
  9. Phil
    19 Jul 2001
    ok, just re read your post...g450
    could be not getting enough air, they do only have passive cooling.
    Don't do somthing silly though like put a blorb on there, you'll prolly make it worse :D
    if you can, open yer case up, and use a probe (read 'finger') to check the gpu Heatsink and CPU heatsink temps at the points where it crashes...if its bloody hot (be careful there) you may have found the problem...
  10. Cheese
    Cheese Doc
    6 Oct 2001
    I agree with Phil on the overheating front... does the problem still persist if you take the case side off?
    Cheers,
    r.
  11. vivid
    24 Sep 2001
    well what cooling would be best for my gfx card then , and where can i get it?
  12. Ataraxia
    Ataraxia <b>OOH BABY!!!</b>
    12 Mar 2001
    Yep I think phil's hit it on the head there.. i've had exactly the same thing with my G400 and with my old Voodoo card
    edit: uh oh, only one away from post 666....
  13. Cheese
    Cheese Doc
    6 Oct 2001
    The crystal orbs are nice... OCS will probably be selling them. The easiest thing would be to buy a slot cooler though... sits in the slot next to your graphics card (assuming it's free) and churns hot air out the back of your case. Most overclocking stores sell them :D
    r.
  14. Phil
    19 Jul 2001
    Before you go buying cooling for your GFX card, check the temps with you finger...make sure it is the gpu and not the main cpu...
  15. vivid
    24 Sep 2001
    ok will do hnx phil and cheeseman
  16. Lordflash
    Lordflash What's a Dremel?
    27 Aug 2001
    Also if it is your grfx card get a fan off an old heatsink if you have one lying about and just try n wedge it on to see if it helps. If it does make a difference then go out and buy a proper solution to the problem
  17. RTT
    RTT #parp
    12 Mar 2001
    ask yer dad if you can fiddle with his PC first man :)
    what bugs me is that its only just started having this prob, the prob hasnt been there from the start??!!
  18. macroman
    macroman The One
    3 Sep 2001
    If it's any help, I have recently had a G400 and a G450 die. Both are well over 6 months old. First they started to freeze and then take ages to initialise and finaly kaput!
    Personally, rather than mess with cooling, I would change to a GF MX based card which are now very cheap.
  19. Cheese
    Cheese Doc
    6 Oct 2001
    Could be dust build up in fans... makes em less efficient, etc...
    It is strange I know, but running with the case side off should prove if it's heat or not, and if it is it's easy to solve :)
    r.
  20. Ataraxia
    12 Mar 2001
    what are you doing to them man?? my G400's been running FINE at 124mhz system bus for the last year!
    me 2..
