i just put ma processor to 950mhz and the gfx card is working fine, i have just been playing cs and rtcw perfectly wierd pc i got
im suprised that that fop32 you got cant cool that tbird 850 @ 1g??? has ya dad used ASII? or is he using the TIM?
say what now? it used to cool perfectelly at a gig but not anymore it seems my pc is just wierd all round
has he used arctic silver or is he using the TIM (thermal interface material ) that comes with the heatsink? the TIM is this stuff -
The extra heat from your cpu @1gig might be causing your graphics card to overheat... What's cpu temp when your proc is at 1gig and full load? As I said before I'd try running with the case side off, if this solves your problem you know there's too much heat somewhere, and if your cpu 'aint too hot (less then 50*C) it's probably your graphics card... r.
