HTPC Sub-£50 TV tuner card
Discussion in 'Hardware' started by Astraeus, 27 Aug 2009.
  1. Astraeus
    Astraeus I hate computers.
    31 Jul 2009
    Is this Compro card as good as I'll get for under £50? Needs to be DVB-T and nothing else besides with price and ease-of-use the main issues for me.
    Or also just seen the Hauppauge Nova-T 500. This seems a better option. Am I right in thinking that this will work with a normal RF aerial?
    Thanks.
  2. Fazed
    Fazed Minimodder
    5 Jul 2009
    If you can find another £3, Hauppauge Win-TV-Nova TD500 is worth a look.
    Twin DVB-T Tuners, no analogue and Remote included. Free delivery at eBuyer also.
    http://www.ebuyer.com/product/113946
    lol...you edited whilst I was typing!
    Yes, will work with a standard co-ax jack.
    pimonserry likes this.
  3. Astraeus
    31 Jul 2009
    Thanks very much for the advice Fazed, will go for that one! :thumb:
  4. Nippon109
    Nippon109 What's a Dremel?
    4 Jun 2009
    don't wanna hijack this thread, but just have a couple of quick questions...
    1) what aerial does one need for TV cards?
    2) does one need a TV license to use these?
    Cheers as always
  5. Fazed
    Fazed Minimodder
    5 Jul 2009
    1. Standard RF Coax jacks, the same as you would plug into your Freeview box / TV.
    2. Yes, absolutely.
  6. Nippon109
    4 Jun 2009
    Thanks Fazed
  7. thewelshbrummie
    thewelshbrummie Minimodder
    29 Aug 2009
    If you only need digital I'd avoid the T750F - having bought one myself I was disappointed to fingd that it's a hybrid analogue/digital card with ONE digital tuner, not two as advertised. It may do FM/video-in and have various other analogue video inputs/outputs but dual-digital cards are a better shout.
    I switched to the E700, Compro's dual digital card. It uses PCI-E x1 whereas the Hauppauge Nova T500 is PCI - the reason I bought the former and avoided the latter. Apart from the interface and bundled software they both do the same... I guess it depends on which mobo slots you have free as to which is the better card (the Compro is £56 at Ebuyer).
