A/V Sub effectiviness
Discussion in 'Hardware' started by Isuo, 15 Feb 2005.
  1. Isuo
    Isuo What's a Dremel?
    13 Oct 2004
    Ok, so I'd just like to know, that what place and what material gives you the best bass sounds.
    eg, In the corner surrounded by brick walls...
    In the middle of the room...
    Just to give you the idea of what I'm asking.
  2. m4rk3d
    m4rk3d Minimodder
    15 May 2004
    The best place for a sub is generally in the corner of a room, facing into the wall. the material can affect the sound, so it's best to experiment and see which corner gives you the best sound/feel.
  3. fathazza
    fathazza Freed on Probation
    20 May 2002
    depends which way the sub fires, and if it fires down it also depends on the flooring/carpets...
  4. Isuo
    13 Oct 2004
    OK, thanks.
    Btw, one thing, does the temperature and space effect the subs effectiviness?
  5. dom_
    dom_ --->
    4 Jan 2004
    the room size will, temperature wont.
    also the layout of the room will.
    this will be marginal changes though. as said experiment with it. although you wont notice much if any difference from a less expensive sub in a plastic case.
  6. ab1385
    ab1385 What's a Dremel?
    29 Aug 2004
    The 'best' way to test a good place for a sub is to plug in only the sub and play something through it, place the sub in your listening position, and move around the room. Wherever the bass is loudest is a 'node' and probably a good place to put a sub. :)
