Build Advice Super budget restricted build
Discussion in 'Hardware' started by mattyh1995, 20 Sep 2012.
  1. mattyh1995
    mattyh1995 Minimodder
    1 Oct 2011
    Greater Manchester
    I have a friend who needs a PC, has trouble saving and can't really manage money.
    He needs a from scratch build for the minimum possible to be used for gaming (Borderlands 2, TF2 and others).
    I can't really provide a budget, but it needs to be as cheap as possible and still be "acceptable" for gaming. Any advice will be welcomed as I don't really know the budget market too well.
  2. lm_wfc
    lm_wfc Minimodder
    18 Feb 2011
    I'd go with a socket 1155 pentium, then you can upgrade easily. You can spend more on the gpu that way
  3. JY_OC_HX
    JY_OC_HX Minimodder
    2 Feb 2011
    Somewhere UK
    No build advice as such. More just general help with the penny pinching.
    Once you figure out what you want, head over to the market place and put up a new wanted list. You may find a real bargain. I have a box full of cables, if you let me know what you will need i can let you have them for postage. Just PM me when you have more of an idea and we can sort something out.
  4. mattyh1995
    1 Oct 2011
    Greater Manchester
    That's what I was thinking. But what GPU would be appropriate?
