Scratch Build – In Progress Superior MSI Battlepack
Discussion in 'Project Logs' started by BaluC, 3 Feb 2017.
  1. BaluC
    BaluC What's a Dremel?
    1 Nov 2014
    Hi All!
    SocceR and I return with our new mod, inspired By Battlefield 1. The plan was to create a military design, based on the superior battlepack, sought-after by many players because it holds legendary weapons.
    Inside the battlepack is a watercooled build which was a bit tricky to pull off in this construction, as this is the flattest fully watercooled system we ever built. Because of this we used a record amounts of fittings.
    The HW seated in our battlepack:
    • MSI Z270 Gaming Carbon mobo
    • Intel i7 6700K CPU
    • MSI GTX980 Ti GPU
    • 4 x 4GB HyperX Predator RAM
    • 240GB Kingston Savage SSD
    • Enermax Platimax 1350W PSU
    • Fully custom Bitspower hardline loop woth Corsair SP120 fans
    Below you can see the fully documented assembly and construction of our mod, including the construction of a life sized .270 caliber rifle prop to accompany the Z270 chipset:
    (The box is fully handcrafted, equipped with working security locks, I hope I won't lose the key :D )
    We'll soon show you the pictures of the finished mod!
  2. BaluC
    1 Nov 2014
    Final pictures
    Here are the final pictures, we brought a Video as well!
