Electronics Surface mount 8-pin PCI-E power socket required.
Discussion in 'Modding' started by Delphium, 6 Apr 2011.
  1. Delphium
    Delphium Eyefinity enabled
    18 Mar 2007
    Hey all, I am hoping you may be able to help me locate an 8pin PCI-E power connector.
    I am essentially looking to replace the connector on a gfx card and I am sturggling to find the connector with the pins to solder it onto the board.
    I have found some which are without pins and I think are desgined for use on the end of a cable rather than having solid pins.
    The closest I have found to what I am lookin for is this.
    http://uk.farnell.com/molex/39301080/header-mini-fit-r-a-w-peg-8way/dp/9963391?Ntt=9963391
    However this is a 6pin in the image but 8pin in the description, trouble is I cant tell if it has the correct notches in each of the pins to correctly fit a PCI-E connector.
    Anyone have any suggestions? :)
    Many thanks.
    Delph.
  2. asura
    asura jack of all trades
    22 Apr 2009
    Farnell aren't very good at putting the correct images up, a good example of this is with fans, where there'll be the same picture for a 80, 92, 120 & 140mm fan of the same model. It saves them time (and therefore money) to do things like this. The description seems very through, I'd just go right ahead and buy it, it's almost certainly exactly what you want; but if you're feeling cautious about it you could always e-mail/call them to confirm.
  3. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    unless you've broken the pins off of the vga card, all you really need is the plastic caps for the male connectors. the male pins are the same size on both cables and pci-e 8pin / eps pcb mount.
  4. Delphium
    18 Mar 2007
    I will need the pins idealy, and worse come to it i just cable it and find another way to mount the plastic block.
    Will give em a call and see what they say, previous experience with calling them has not been awesome in the past, specially when the block has the notches cut out, so they would need to physicly check it.
    Cheers.
  5. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    It looks like the right one to me, assuming you want right-angled pins?
    The notches will be the same on all 8-pin connectors, they are all part of the same "Mini Fit Jr" range by Molex.
  6. Unicorn
    25 Jul 2006
    Can I ask why you're changing it and what card it's on? Because honestly, unless you have a reflow/rework station, you're not even going to budge that lead free solder
