Surveillance software advice
Discussion in 'Software' started by homebrew, 13 Nov 2020.
  1. homebrew
    homebrew What's a Dremel?
    13 Mar 2020
    I am just in the process of purchasing IP CCTV cameras to install around my home. I am trying to find the best software to run of a Windows laptop so I can manage and monitor the cameras through the surveillance software. Has anyone had any experience of using this type of software?
  2. saspro
    saspro IT monkey
    23 Apr 2009
    BlueIris works with most cameras & makes a good DIY NVR (you'll need a dedicated box to build it on)
  3. creative
    creative 500rwhp
    23 May 2014
    or if you go the linux route, shinobi is worth a look.
  4. Byron C
    Byron C I was told there would be cheesecake…?
    12 Apr 2002
    Same here to suggest this. I run it on a Raspberry Pi 3 with a single camera, but I could probably add more cameras quite easily. I don't have any motion detection or anything fancy set up, just pure video stream copy to an external USB rust spinner.
    13eightyfour likes this.
