Windows Systems Crash
Discussion in 'Software' started by GavinH, 30 Sep 2011.
  1. GavinH
    GavinH What's a Dremel?
    31 Mar 2011
    Hi,
    Guys my system carshes while I play certain games... "The Witcher 2, Borderlands and F1 2011". All my other games run fine... any idea's???
    System: 965 BE Stock, ASUS M4A87TD EVO, 4 x 2 GB G Skills 12800, MSI 6850 Cyclone HD, Win 7 64 bit.
    I'll be mid game and the system will just freeze with buzzing audio.
    Any ideas?
    Gav:waah::duh::rock:
  2. Landy_Ed
    Landy_Ed Combat Novice
    6 May 2009
    What are the games that don't crash - are these maybe pushing them a little harder? Running the latest good drivers?
    Drop some temp & load monitoring software & keep an eye on the counters, might give you some insight.
  3. GavinH
    31 Mar 2011
    Hi Landy_Ed,
    Games that dont crash... "BFBC2, BLOPS, Crysis + Warhead, Star Craft II, Metro 2033, Civ IV and Civ V" Temps are well within tolerance. All drivers are up to date... been through and updated each driver. I have exhausted all the standard/usual avenunes...
    any ideas?
  4. longweight
    7 May 2011
    What does the event viewer have to say about it?
  5. Landy_Ed
    6 May 2009
    hmmmm. Wasn't expecting to see Crysis on that list. so likely not the GPU overheating then.
    Swap those ram chips around a bit, maybes take 2 out, if all hunky dory, swap them with the other 2, see if all is still ok. I did have issues myself some time ago with one ram chip having a fault, mostly everything was fine unless I used something that just happened to touch > 5gb.
  6. GavinH
    31 Mar 2011
    Hi
    Landy_Ed
    I'll swap my RAM around thanks for input.
    Longweight
    My event viewer states alot of errors and warnings?? What do you want me to look for??
    Could it be something to do with my AV??
    Thanks Gav
  7. Xcellenye
    Xcellenye What's a Dremel?
    30 Sep 2011
    Does the whole thing freeze so you have to reboot or can you get back to desktop?
