Cooling TEC Units in the Kobalt Deadalus
Discussion in 'Hardware' started by n0va, 11 Dec 2009.
  1. n0va
    n0va Burnin'!
    27 May 2009
    Hey guys :)
    I've been interested in TEC Cooling since I read read about the concept after seeing it in craigbru's Rogue project first. But I've never seen many real applications or anyone really using it here up to now.
    That's why I was very surprised when I read about the Kobalt Deadalus Dream PC a while ago, when they had these featured, it claims to have 18 CoolIT TEC units and according to the reviews I read, these work fairly well. Of course, I instantly went to the CoolIT page, only to find out that the last TEC they had released was 3 Years old and not only ugly, but also extremely expensive at roughly 400 quid and also not very efficient compared to modern WC loops.
    So, my question is: Where the heck did the guys from Kobalt Computers get these nice TEC Units, and how did they manage to integrate them into the loop with the quad Rad and make them work so well? I'm interested in any hint that could lead me to getting one of these precious things, cause I'm kind of a fanboy of exotic technologies :p
    EDIT: Forgot to post the Link to the Deadalus ^^ Here you go: Clicky
  2. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    that's bespoke engineering, not off the shelf solution.
  3. n0va
    n0va Burnin'!
    27 May 2009
    Dammit >.<
    So you basically mean there is no chance to get an up to date TEC with good performance that can be integrated in a water loop? That would be sort of sad -.-
  4. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    My guess : instead of using one very expensive TEC running at the raggedy edge of it;s performance, they're got 18 much cheaper, less powerful TECs, and are running them at their optimum efficiency (rather than maximum output). Shouldn't be too hard to do yourself if you;re already comfortable working with a single TEC.
    As for layout, you'd simply have two loops. One loop with CPU/GPU/motherboard/etc + cold side of the TEC, and the other with the hot side of the TEC + the radiator(s). You could either do what Kobalt have done and get a big custom heat exchanger made on a CNC mill, or you could use a whole bunch of cheap waterblocks with the TECs sandwiched between them. The more TECs you use, the more cost effective the custom block would be.
  5. Frohicky1
    Frohicky1 Awaits his moosey fate . . .
    16 Apr 2009
    You don't have to TEC cool the water; the Daedalus solution is quite an unusual one. Most TEC user slap it onto the cpu, then watercool the back of the TEC.
  6. edzieba
    14 Jan 2009
    True, but using a TEC directly requires a very powerful, and thus very expensive, TEC. The TEC must be able to transport more energy than the processor can emit as heat, or the TEC will heat the processor rather than cooling it.
    Say you have a CPU that emits 150w heat at peak. A TEC is not 100% efficient, so putting a 150W TEC on that CPU will make it hotter, not cooler! If the TEC is 75% efficient, than you need a 200W TEC just to keep your CPU at the SAME temperature as before. To actually get any net gain, you would probably be pushing 250W for the TEC alone, and a TEC that powerful won't be cheap, and you will now be drawing 400 watts of power! This 400w will also need top be dissipated as heat, requiring a much larger radiator too. The advantage of using multiple lower power TECs is that they are more efficient in terms of energy usage, and much cheaper.
  7. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    If you go to the Kobalt forums and speak to neil, he might be able to hook you up with the TEC's that Kobalt use.
    EDIT
    Andrew from kobalt posted this on the Deadalus thread.
  8. n0va
    n0va Burnin'!
    27 May 2009
    Awesomeness! Thanks dude!
