Where is the most suitable place for temp probes for the cpu and gpu to be attached i have a dual watercooled loop and want to be able to view temps on the fly on my lamptron touch
Thanks- i think i will get a couple of water probes- probably neater to use a fitting type one and would it be best to put it on the inflow or outflow of the cpu and gpu loop
It's not going to make a big difference. Providing you have sufficient rad(s) for your heatload the temps aren't going to vary by much throughout the loop. I'd put them in the most convenient location.
