Overclocking Temperature issues
Discussion in 'Hardware' started by mm vr, 17 Jul 2009.
  1. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    I'm overclocking my CPU, and before I start, here are the specs:
    - P5Q Pro
    - Q9550
    - 4 sticks of 800MHz CAS4 Corsair XMS2 at 2 gigs each
    - TRUE
    - Antec P182 (currently having the side panel open)
    Using RealTemp and Everest to monitor my temps, both using a TJMax of 100°C. Stressing with LinX.
    It has been like this from the beginning. Idle temps are in the 40°C mark, and load temps at stock clocks & voltages approach 60°C.
    Applying an overclock, gotten it easily up to 3.4GHz now (1.285VCore, 1.26VTT, all other voltages manually set at minimum). Load temps over 70°C, the Q9550 is specced for 71.4°C which worries me.
    Also worth noting that the heatsink base (ontop of the CPU) barely feels warm even if the temperature reported is 70°C. So either it is a miscalibrated sensor or a very badly seated heatsink.
    AFAIK, the heatsink is correctly seated, with correct amounts of TIM applied, but who knows. Reseating the TRUE is the last thing I want to do, it's such a job! :p
    Any ideas? Ill be happy to provide more info if necessary.
  2. mm vr
    18 Nov 2007
    Any ideas what could cause it?
    Could it be that my TRUE's bottom is not flat at all like Pookeyhead's?
  3. Pookeyhead
    30 Jan 2004
    Whether it's caused by that or not, the fact is you will see a large improvement if you lap it... so that's what I'd be doing first.
    I don't know much about overclocking quads, so can't comment on your temps... but get that TRUE lapped. :)
  4. mm vr
    18 Nov 2007
    Hmm, lapping is something I'd rather not do actually. Not only because it takes years to do!
    It also has half a year of warranty left, but I guess nothing can go wrong with a heatsink. :)
    I'll check if it needs lapping at some point if I have time to remove the mobo.
  5. Pookeyhead
    30 Jan 2004
    You may not need to remove the mobo. My mobo holds the TRUE's backplate in place when I remove it.
