Planning Temperature/load-based widgetry
Discussion in 'Modding' started by RedFlames, 9 Aug 2018.
  1. RedFlames
    23 Apr 2009
    Not sure if this is the right place for posting/asking but here goes...
    A friend is asking me to build a PC for a collegue of theirs and after a conversational tangent than typically only comes about through beer and boredom modding came up...
    Specifically: Modding a temperature- [or CPU load] controlled hamster wheel.
    Now, i can think of 2 ways to do this...
    a motorised hamster wheel with the rpm controlled/linked to temp/cpu load...
    some sort of screen/display displaying a sprite/anim based on same.
    How would you lot approach it?
  2. Cheapskate
    13 May 2007
    No clue on the coding side, so I'd try ripping the blades off a PWM fan and glue a pulley to the hub.
    I'd include a screen display with hamster animation behind a real wheel if possible, But that would involve animation and R-pi/Arduino coding.
    Hilarious idea, BTW.
    RedFlames likes this.
  3. Nexxo
    23 Oct 2001
    I'd perhaps buy one of those mechanical hamster-in-a-wheel toys:
    The wheel is about 6"/15cm in diameter; the hamster is powered by two AAA batteries, delivering 3V.
    Basically you remove the batteries and discretely run a wire from the hamster to an Arduino which feeds the hamster through one of its PWM outputs, as a function of CPU load or temperature data fed to the Arduino by USB. Simples!
    Cheapskate and RedFlames like this.
