Planning template design software
Discussion in 'Modding' started by honyin, 7 Jul 2009.
  1. honyin
    honyin What's a Dremel?
    8 Mar 2009
    hi im looking for software to design my own templates for fan grills and side panels to print and cut any help would be great.
  2. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    Any cad program would do. Also, most photo editors like Photoshop and Paint Shop Pro can handle it.
  3. Cookie Monster
    Cookie Monster Multimodder
    27 Aug 2003
    Not that it should matter but how are you going to get them cut? If your going to take them someplace to get them machined why not ask what software that company has that way you don't spend weeks designing it in Photoshop, only to have to redo it in AutoCAD because the company can't convert it.
  4. Javerh
    5 Sep 2006
    He mentioned printing, so I'm assuming he would just glue the template and cut away with a dremel.
  5. Cookie Monster
    27 Aug 2003
    I really should read posts fully before replying
  6. ModMinded
    ModMinded Are you throwing that away?
    26 Aug 2008
    Sketchup in 2d mode would be good as well, probably. It's free! (I'm still learning, but it would be very easy to do an accurately measured layout, I think.)
    I've seen a lot of people using coreldraw for their templates.
  7. honyin
    8 Mar 2009
    cheers guys thanks for the advise.
  8. forester joe
    forester joe shhh. can you hear your PC?
    24 Oct 2005
    what about scale?
    How do you make sure that the printout is to scale? :dremel:
  9. dan-ere-07
    dan-ere-07 What's a Dremel?
    29 Mar 2007
    Mesure it?
    Im shure if you mesure a few of the dimensions and they are what you put in it will be fine. :thumb:
  10. ModMinded
    26 Aug 2008
    Sketchup has some cool tools for that, that allow you to accurately laydown measurements in various units (mm or inchs, etc) Also, there is a scale adjustment feature as well.
    http://sketchup.google.com/support/bin/answer.py?hl=en&answer=36227
  11. forester joe
    24 Oct 2005
    will definitely look into this.
    the problem I see, is that the 2D image scope is not clear, as well as the zoom.
    will have to see how sketchup handles this.
    TKS
