Case Mod - In Progress The Borg
Discussion in 'Project Logs' started by Toppy, 2 Mar 2012.
  1. Toppy
    Toppy What's a Dremel?
    1 Mar 2012
    This is a mod im working on ..i noticed mountain mods were expensive for what they were offering with the perspex cases...so my general idea was to build on as cheap as i could...but its got out of hand now and i want to mod it some more.. i have completed the case now all made from perspex..but i still have to do all the mould out of resin for the outer shell of the borg ship...anyway afew pics from start to where i am at now..hope you like...
    Started out cutting some fan grills out
    Then was after the general layout of things inside the case
    case held together with masking tape to see if it all sat pritty :)
    With the mobo try in
    This is the hard drive bay i have created ... it has the curve in the bottom so a bigger graphics card can fit in...plus a ssd will fit in its shell on the bottom of the unit perfect..when i purchase 1 that is.
    I bought some temp read outs for cpu and hdd
    Cut out a shape like the fans for the side window then lightly sanded all panels on the case for the spray job.
    Sprayed
    With the lights inside as a quick test
    Installing the gear
    With the window
    Inside lit up
    How it is at the moment and the resin moulds im working on to cover the case with ..this isnt going to be the mould im going to use it is just a test sample ..but you get the general idea
    Well i hope you like my mod sofar...keep smiling :D Will post more once i have worked on the moulds.
