Notebooks The Common Battle
Discussion in 'Hardware' started by DSquareD, 6 Sep 2009.
  1. DSquareD
    DSquareD What's a Dremel?
    24 Nov 2005
    Hey all,
    Been a while since I've posted. Jees need to get back on this place.
    I have NO doubt that this question has been asked here before, but, having said that, I cannot find anything yet.
    I need a netbook to serve as a work computer for University. The specs of netbooks is fine for what I need it for, so it's not so much a debate of if I should get one, but rather which one I should get.
    It's down to the Samsung NC10, the MSi U100 Wind, and the Lenovo S10. I know that the reviews on bit-tech here gave the NC10 the best rating so I am inclined towards it, albeit a bit more expensive. Which would you recommend (based on looks, form, function, reliability, battery and overall "wow factor")
    Thanks.
  2. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    I dont think you will be dissapointed with any of them, if you can afford the Samsung go for that.
  3. Gryphon
    Gryphon What's a Dremel?
    24 Apr 2009
    I'm looking at getting a netbook for uni too. I'm tempted by the Asus 1005HA. It's main appeal is the 8-9hour battery life, although it looks amazing too (its the newer 'seashell' model). Also it's cheaper than the Samsung...
    It's had some very positive reviews if you look around...
  4. damienVC
    damienVC What's a Dremel?
    25 Aug 2009
    NC10 without a doubt. I've had one for about 6 months and it's an absolutely cracking piece of kit. If you look at most of the review sites it comes out head and shoulders above the rest (PC Pro A-list etc etc). I use it for my uni work, it runs Word with Endnote in the background, the battery lasts for ever and it doubles for films as well (with some decent headphones though). It might be a bit extra but is well worth it. Very highly recommended.
  5. Fredrics
    Fredrics Hmm...
    31 Dec 2007
    In my opinion the best thing to do is to go down to your local pc mega store and try them all out. I find that some of the manufacturers decide to place the track pad and click buttons in the most awkward places. Furthermore models such as the Samsung N310 have a really sharp edge around the keyboard housing which makes it uncomfortable.
  6. wyx087
    wyx087 Multimodder
    15 Aug 2007
    the most important factor in netbooks is the keyboard. so as above said, go to the local store to check it out.
  7. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
  8. damienVC
    25 Aug 2009
    The NC10 has got the closest to a regular size keyboard of the current crop of netbooks AFAIK. Did I mention I like them?
  9. flibblesan
    flibblesan Destroyer
    27 Jul 2005
    S10 is brilliant and has a great keyboard. The S12 is about also which is a little bigger and has a full size keyboard.
