Case Mod - In Progress The Green Way 2.0
Discussion in 'Project Logs' started by Hostiti, 17 Apr 2015.
  1. Hostiti
    Hostiti What's a Dremel?
    10 Mar 2015
    Hi all...
    I'm starting the version 2.0 of my mod The Green Way :
    The main objective is to spend 2 gpu in watercooling (1 gpu will be removed)
    To do this, I'll have to change the water cooling circuit by adding rad and I will pass the tubbing 10/12 to 10/16
    Many other modifications will be made to this project.
    My sponsor(s) for this project :
  2. Hostiti
    10 Mar 2015
    Hi all!
    I received my EK's components!!! Time to pictures :
    EK-CoolStream RAD XTC (280) :
    EK-HD Adapter 12/16mm - Black :
    EK-Supremacy EVO - Acetal :
    EK-DDC X-RES DSQ :
    EK-RES X3 - TUBE 250 (204mm) :
    EK-RES X3 - Multiport TOP + EK-RES X3 - TUBE 250 (204mm) :
    I just dismantles all my current watercooling ...
    Do not forget that this PC is the one I use every day. I'll put a little more time than expected to reorganize
  3. Hostiti
    10 Mar 2015
    Hi all
    New starting point , I have to fully empty the case to provide a new PSU cover
    I have a little progress on this project. Also , thank thermaltake who agreed to help me.
    The screws on the upper part will be replaced by rivets , unlike other countersunk screws that will remain in place for it to be easily removable
    Having chosen an easily removable PSU cover allows me to retain access to my HDD rack
    We see here some spacers that allow me to set me straight on the rack ( screws will be cut later)
  4. Hostiti
    10 Mar 2015
    This time , the tubbing started .
    I have just slightly over- raise the pump otherwise it will pinch the top of the tank ( between GPU1 and res) , and then I will go down to 1 or 2mm tube that passes between the two rad ( ca looks very very light)
  5. Hostiti
    10 Mar 2015
    Hi all :D
    I'm back to announce you that the tubing is finaly done.
    I also received a packet this morning from Thermaltake who offered me 7 Riing14 (big thank to them)
  6. stealth80
    stealth80 Minimodder
    1 Feb 2015
    Looks very nice so far. Why did you remove the 3rd GPU?
  7. Hostiti
    10 Mar 2015
    I am not really convinced by the 3way SLI performance compared to 2way... And I also need a little money to finance the project .
  8. Hostiti
    10 Mar 2015
    Hi all!
    Here is the last pix of my mod The Green Way 2.0 (the inside)
  9. Hostiti
    10 Mar 2015
    Now I have to finish the case modification :
  10. amagriva
    amagriva Minimodder
    13 Jun 2009
    Wow beautiful, very clean execution but, if I may, in my humble opinion the diagonal tubes are a punch in the eye but it is your mod so...
  11. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    diagonal is fine for me. may be some more diagonal accents would be nice...
  12. Hostiti
    10 Mar 2015
    Hi everybody!
    After some troubles with my pump (which finally passed away), I left my side project for some time
    But for one week, it's going a lot better ... The PC is running again :thumb:
    And waiting to finish the outside of the box (which has not advanced since the last time), I tackled the RAM sticks.
    I had enough of Corsair Vengeance LP ... I have therefore replaced by Trident X I am eager to repaint :D
  13. Concept73
    Concept73 Wannabe modder.
    30 Aug 2013
    Love the lines of your tubing, great work!
