The Invisible Case
Discussion in 'Article Discussion' started by linear, 24 Feb 2002.
  1. DETN8R
    DETN8R What's a Dremel?
    27 Oct 2001
    Did you have to ground the motherboard stand-offs?
    I just read something about grounding them.
  2. codeflux
    codeflux What's a Dremel?
    26 Nov 2002
    uhm... did you see the latest MAXIMUM PC?! this rig made the "rig of the month"! congratulations to linear - job well done. although macroblack would definitely be my number one vote. :)
  3. Transic
    Transic What's a Dremel?
    4 Dec 2002
    Just brilliant...the FAQ on your website about plexi techniques was fantastic, gave me a huge heads up my project ahead! We shall see how rounded plexi corners go.... :D
  4. Arlof
    Arlof What's a Dremel?
    2 Aug 2002
    Locating Some Acrylic Rodding?
    Hello, I've been sorta fooling around with the idea of making a case very similar to yours. I've got some of the building materials but, I've had no luck finding acrylic roding or any transparent rodding at all. Checked HD plus some other hardware/hobby shops to no avail. Any suggestions?
    Regards,
    Arlof
  5. the pip
    the pip What's a Dremel?
    18 Jun 2002
    hey arlof, try
    here
    and linear, can you give me the exact url for those plastic screw thingies you used. i can't find them for the life of me.
  6. linear
    linear Minimodder
    5 Oct 2001
    Thanks, el bob, 3 months was calendar time--a lot of that was spent obsessing, uh I mean, thinking about the details, or trying to solve a design problem, like how to mount the drive cage.
    Are you the same el bob from [H]? Either way, welcome to the boards.
  7. linear
    linear Minimodder
    5 Oct 2001
    exact url for plasic thingies
    I believe I used the 3/8" and trimmed them down.
  8. certhas
    certhas What's a Dremel?
    16 May 2003
    @linear
    where did you got those acryl-hings ? i searched the web but didn't found anything.
    certhas
    btw. nice case :D
  9. linear
    linear Minimodder
    5 Oct 2001
  10. certhas
    16 May 2003
    if you would take money for it i would call it great customer service :D
    thanks alot, i just contacted my "local" online-material dealer :D hope they have those too.
    btw. is the glue you used hardened with uv-light ? i have read the example of use and it's similar like the glue i've found.
    i'm still not sure if i glue or screw my imagined plexi-cube. :wallbash:
    certhas
  11. linear
    linear Minimodder
    5 Oct 2001
    No, my adhesive was strictly a sovlent cement, no cure other than letting it evaporate.
    Definitely glue it. It looks 10x better.
    You should do one thing I didn't--have the glue joints running parallel to the line of sight wherever you can. It's even harder to see them edgewise than it is to see them looking at the flat. I should have used hte 9.5x9.5 faces as my front and back, but I used the 10x9.5 faces instead. A small detail, but worth pointing out.
  12. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    thats a well sweet project:D
  13. linear
    linear Minimodder
    5 Oct 2001
    Thanks, dude, it was fun. :dremel:
  14. Sc0rian
    23 Feb 2003
    hehe bet it was
  15. Fu7ure7ech
    Fu7ure7ech What's a Dremel?
    20 Jun 2003
    Just got around to reading this article. All I can say man is good job. You defined building your own pc lol. Great work and I hope to see more from you. BTW this took a total of 3months to build?
Tags: Add Tags
