News The Mineral Oil PC
Discussion in 'Article Discussion' started by CardJoe, 15 Sep 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. yuusou
    yuusou Multimodder
    5 Nov 2006
    One word. Awesome. Another word. Amazing!
  3. Kiytan
    Kiytan Shiny
    2 Jul 2009
    with those lights going it looks utterly fantastic. Great mod.
  4. Fractal
    Fractal I Think Therefore I Mod
    9 Apr 2010
    An ambitious and complex project but perseverance and attention to detail have obviously won out. Well done!
  5. dispie
    dispie What's a Dremel?
    4 Jun 2010
    wooo very very nice
  6. stupido
    stupido What's a Dremel?
    30 Nov 2009
    Very nice...
    Did you tried any overclock?
  7. Necrow
    Necrow Minimodder
    24 Feb 2009
    Mod of the year nominee I expect.
    What a fantastic creation and a lot of lessons learned the hard way. Hats off to you fella.
  8. cjmUK
    cjmUK Old git.
    9 Feb 2004
    Well it wins on the originality stakes... But I wouldn't want to be buying his used components on the BT Market place...
    Just think, if you used a Pentium 4 Extreme Edition chip, it could double up as a deep fat fryer....
  9. Fabou
    Fabou What's a Dremel?
    22 Apr 2010
    Really nice. But too bad you have not been able to get the pump lying on the floor.
  10. -SambaL-
    -SambaL- What's a Dremel?
    15 Sep 2010
    + No more dust in your case.
    - Upgrading has got to be a bitch.
    Either way it looks awesome.
  11. Tattysnuc
    Tattysnuc Thinking about which mod to do 1st.
    19 Jul 2009
    Nicely done, but I'm getting a feeling of deja vu here.
  12. Hakuren
    Hakuren What's a Dremel?
    17 Aug 2010
    Bonkers but in a good way! Really impressive work and original approach.
  13. legoman666
    legoman666 Beat to fit, paint to match.
    24 Aug 2003
    Thanks everyone!
    Not yet. It seems fast enough as it is, and resetting the bios if i OC too far is a major pain in the arse.
    Haha, I've actually sold several components that were in my original Q6600 setup: the Q6600, the RAM and the sound card. People bought them even though I mentioned that they were submerged in oil for a few months.
    I know :( And now the PVC tubing is so stiff that it's impossible to bend without cracking.
  14. legoman666
    24 Aug 2003
    Also, you spelled my name wrong; it's Mollmann, not Mollman ;)
  15. r3Q
    r3Q Minimodder
    31 Jul 2002
    if you want to be able to reset your CMOS settings for overclocking, you can get an external switch. easy enough to install - just put the little jumper pin on and extend the wires somewhere to a switch like this;
    for two pin cmos connector (i would just use a jumper that comes with the motherboard and solder to that so its removeable, instead of soldering to the motherboard)
    http://www.overclock.net/case-mod-work-logs/401028-full-log-external-cmos-reset-key.html
    for three pin cmos connector (i just used a 3-pin CPU fan cable wit the connector on the end that i cut off a fan i had lying around. it fits on there perfect)
  16. WildThing
    WildThing Minimodder
    26 Jul 2007
    Wow great mod! One question though.
    What are convection currents?
  17. docodine
    docodine killed a guy once
    10 Feb 2007
    Convection currents occur when the liquids of a different temperature move around. The hot oil would move differently than the oil fresh out of the radiators.
  18. stupido
    30 Nov 2009
    And you are able to actually see them because the oil with different temperature has different density thus light is refracted...
  19. cjmUK
    cjmUK Old git.
    9 Feb 2004
    More specifically, the hot oil rises and the cooler oil sinks, so there is a circular current of oil - the oil will change viscosity and perhaps colour with temperature, so you will be able to see streams of different temperatures flowing past each other.
    At first, it seemed like an expensive folly, but having already identified its potential as a deep fat fryer, we've now identified that it can also function as a lava lamp... Can we find any more uses for this creation of genius??
  20. legoman666
    24 Aug 2003
    Paper weight, boat anchor, theft deterrent, chick magnet.
Tags: Add Tags
