Guides The Modding Toolbox: A Guide to Drill Bits
Discussion in 'Article Discussion' started by bit-tech, 22 Dec 2017.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
    adidan likes this.
  2. Guinevere
    Guinevere Mega Mom
    8 May 2010
  3. adidan
    25 Mar 2009
    Appreciate this new guide series, very handy for those of us who keep meaning to getting around to modding some of thoee things taking up room in the loft.
  4. Cheapskate
    13 May 2007
    Pretty good guide. I think you should mention that it's a good idea to not hand hold the material when using a hole saw. It's better to have the material against something like a length of angle aluminum clamped to your waste board. This will keep the material from spinning violently if/when the saw grabs.
  5. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    My tip for this article is to look at the tenants of your local industrial estate. There will almost certainly be a tool supplier there.
    After all, if you just want ten 3.5mm bits, why buy an assortment?
  6. loftie
    loftie Multimodder
    14 Feb 2009
    As a non modder who's on an equivalent level to stick people drawing when it comes to anything diy/manual/etc, I enjoyed the article and found it interesting. More please :happy:
    adidan likes this.
  7. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    This was a bit of a good bit about bits on Bit.
    adidan likes this.
  8. adidan
    25 Mar 2009
    Which bit?
  9. VipersGratitude
    VipersGratitude Multimodder
    4 Mar 2008
    Some useful info in case anyone can avail of it...
    RedFlames and adidan like this.
  10. Mr_Mistoffelees
    26 Aug 2014
    Old fashioned hardware shops are good for such things too. Probably have what you want lurking in a box or draw somewhere in the shop.
  11. RedFlames
    23 Apr 2009
    Currently typing that into a [searchable] word doc, if anyone is interested...
    ...why yes, I am bored, how did you tell?
    VipersGratitude and adidan like this.
  12. Dave Lister
    Dave Lister Minimodder
    1 Sep 2009
    Glass/ceramic bits are handy too especially with a lot of case manufacturers now using tempered glass, I got a nice little set earlier in the year for about €25 so I could pass a cable through glass. It's worth noting you need to put minimal pressure on them when drill though as glass shatters easily.
  13. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    Wow this had quite the reception haha, looking forward to growing the series a bit. Could be an interesting idea to add some of the suggestions you've made in, seen a few ones pop up on FB too which could be interesting to include. Thanks for all the wonderful feedback, so glad to see it's welcome direction :blush:
  14. Xlog
    Xlog Minimodder
    16 Dec 2006
    You simply can't drill (or cut) tempered glass. If you drilled one, it was not tempered.
  15. RedFlames
    23 Apr 2009
    You can, but iirc you'll need to break out a laser cutter if you don't want the glass to shatter into a gazillion pieces.
  16. Xlog
    Xlog Minimodder
    16 Dec 2006
    Extremely thin ones, like mobile screen protectors, yeh, maybe. But haven't seen anyone successfully cutting tempered glass sheets used in windows/furniture/pc cases (3mm thick and up). If you have any such examples, please share.
  17. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    Nice but no mention of cooling,drill techniques nor the importance of workpiece holding...especially with the holesaws?
  18. Cheapskate
    13 May 2007
    Those charts are easy to find on the net. Most online industrial supply places have them up for quick customer reference.
    Lube on soft iron: Lard or soda water. -And I feel silly for mocking people using beer for cutting coolant now.
  19. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    So I'm risking sounding stupid hear but why soda water? I noticed it said that in the images of the book
    VipersGratitude posted and now it's been mentioned again, so why soda water (aka:carbonated water) and not just plain old water.
  20. VipersGratitude
    4 Mar 2008
    It inhibits rusting.
    Corky42 likes this.
Tags: Add Tags
