Guides The Modding Toolbox: A Guide to Rotary Tools
Discussion in 'Article Discussion' started by bit-tech, 24 Apr 2019.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Xlog
    Xlog Minimodder
    16 Dec 2006
    Here's a question: are there any rotary tools, apart form Dremel 4000 series, that have constant speed control?
  3. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    I'll second 3M for really nice abrasives, it's just not worth bothering with cheap paper/pads.
    Proxxon's Micromot series (the IB/E and IBS/E specifically) are worth a look as an alternative to the higher-end Dremels. MUCH more sturdy construction, closer to a mini die-grinder. You can also go full-ham and stick them on one of their tiny mill/drill tables if you want to do something bonkers like mill your own custom micro-channel waterblock.
    Xlog likes this.
  4. Mr_Mistoffelees
    26 Aug 2014
    For woodwork, I've used 3M sandpaper but, now use Hermes Perdurable Silicon Carbide Sheets from Axminster, in my experience much more durable and tear resistant, especially sanding over edges and curves.
  5. Cheapskate
    13 May 2007
    Thanks. I know a guy that uses one of those air systems for a cnc spindle and I was wondering what search engine verbiage would bring it up. I also get why he doesn't pay much attention to spindle speeds now. :hehe:
Tags: Add Tags
