Features The Modding Toolbox: Abrasives Part One - Hand Tools
Discussion in 'Article Discussion' started by bit-tech, 20 Mar 2018.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Cheapskate
    13 May 2007
    Lovely article. Yeah, in woodworking or home repair, 240 is considered fine grit. 3000 grit isn't going to do much with most unfinished woods, and for plaster, anything finer will just clog. :D
    There's also 60 and 50 grit for those who do not have rough files/rasps. I have a single strip of 50 grit that has served me well for at least 20 years.
    -We should also mention Swiss-cut files so Nexxo doesn't have to. They are super fine, can be used horizontally, and leave a surface that doesn't need to be sanded.
  3. Cheapskate
    13 May 2007
    Edit: also, there's
  4. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    I mean Switzerland’s a very mountainous place right?
    Aha yes I probably should have mentioned those specifically. That said he’ll be pleased to know I included two brands known specifically for making them
  5. Zak33
    Zak33 Staff Lover of bit-tech Administrator
    12 Jun 2017
    another lovely piece of instruction Alex :) thanks muchly :)
    I do love a cork sanding block.....
Tags: Add Tags
