Photos The 'post your desktop' thread
Discussion in 'General' started by RTT, 26 Apr 2005.
  1. atanum141
    22 Jul 2004
    Tolsk where did u get ur theme from...i like it do u still have a copy???? can u pass it on please.
  2. Nath
    Nath Your appeal has already been filed.
    28 Dec 2003
    If my memory serves me right...it's Longhorn Slate. :thumb:
  3. Malvolio
    Malvolio .
    14 Dec 2003
    It's ok, only a temp background, currently looking for something a bit darker with the same basic theme.
  4. Tolsk
    Tolsk What's a Dremel?
    14 Jul 2004
    bingo, default with with windowblinds
  5. Fusen
    Fusen What's a Dremel?
    17 Jan 2004
    I used to have a smart wallpaper but then I changed it and didn't like the new one so just used a standard colour
  6. cderalow
    cderalow bondage master!
    23 Jan 2002
  7. Barry
    Barry What's a Dremel?
    23 Jan 2005
  8. jezmck
    jezmck Minimodder
    25 Sep 2003
    blimey, that's a lot of quick-launches!
  9. Atomic
    Atomic Gerwaff
    6 May 2002
  10. cderalow
    23 Jan 2002
    second monitor ends up being strictly irc/aim/msn/icq etc.... i'll toss iTunes over there too if i'm using cad or something so i can check songs etc... but other than that, it's simply to unclutter my main desktop.... normally they're not even the same size (my main screen being at 1600x1200 normally)
  11. uwannabigmak
    uwannabigmak What's a Dremel?
    30 Dec 2004
    where are you hosting your images? mine are all too big. even when I scale down 50% its still around 2MB. (of course, it is dual screen)
  12. Zephyr
    Zephyr Go V-Boy, Go!
    1 Oct 2004
    Uh, I fit dual 1600*1200 images, saved at high quality JPEG format, in under 1MB. Hosted on Imageshack until I got my own site. What are you saving them as, bitmaps?
    /me stabs uwannabigmak with omgz0rzMSPaint ;)
  13. Malvolio
    Malvolio .
    14 Dec 2003
    I've never quite understood the point of removing all the icons from a desktop environment. Yes, you're removing a slight bit of clutter, but how often do you actualy sit down and stare blankly at your computer monitor without a program of some sort running?
    A computer should be a work of art, but it also should constitute some function. My most used applications go onto the desktop, and I utilize the links provided (either that or I just use the quick launch features on my keyboard, or my remote-wonder)
  14. jezmck
    jezmck Minimodder
    25 Sep 2003
    i wouldn't like it because there wouldn't be space to show all the different apps I usually have running.
  15. Malvolio
    Malvolio .
    14 Dec 2003
    Maybe it's just because I haven't slept in a few days, but I can't quite work out how having icons set on your desktop would make any impact as to how many programs you are running...
    Can't you just like move a window over the icons if they're bugging you so much? Or change the icon? :confused:
  16. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    I have only the recyicle bin on the desktop. (because i can't remoe it) If i hide all the icons on the desktop it becomes a hazzle to save things there (saved things doesn't show up either). and if i remove the recyclebin i cant put things in it.
    I have quicklaunchbuttons to access programs. the start->programs menu gets used wery rarely. Having icons on the desktop is a waste, as i have to remove windows to get access to them.
  17. jezmck
    jezmck Minimodder
    25 Sep 2003
    I was specifically talking about the quicklaunch (not desktop) shortcuts.
    And looking back, I was actually talking about/to Barry.
  18. M_D_K
    M_D_K Modder
    3 Apr 2002
  19. Shadow_101
    Shadow_101 Minimodder
    12 Feb 2004
    mind if i ask where you got that wallpaper morgan? (on the dual desktop)
    very nice toy btw :naughty:
  20. M_D_K
    M_D_K Modder
    3 Apr 2002
    Its from deciant art drop me a mail and i'll send it over
    [technical@coolercases.co.uk]
    and i had too show som good restraint not too post it lol :p
    morgan.
