Scratch Build – Complete ⭐ THE ROG CORE
Discussion in 'Project Logs' started by TodMod, 3 Oct 2019.
  1. TodMod
    TodMod Minimodder
    14 Dec 2018
    Hi everybody
    after the predator mod, the time has come to put me to work immediately with a new mod, a new scratch build made on a mini itx platform.
  2. TodMod
    TodMod Minimodder
    14 Dec 2018
  3. TodMod
    TodMod Minimodder
    14 Dec 2018
    System configuration :
    Motherboard = rog strix b450-i
    Graphic card =Sapphire Radeon RX 570 4gb
    Ram= 8x2 xpg spectrix d60g 3000
    M2=xpg GAMMIX s11 pro 512gb
    Psu=Riotoro enigma 750w
    Cpu=Ryzen 2600x
    Air cooling =Golden Field lighting ray
  4. warboy
    warboy Insane modder
    24 Nov 2011
    Excellent start TodMod !
    TodMod likes this.
  5. TodMod
    TodMod Minimodder
    14 Dec 2018
    Well guys, it's time to get to work. I state that it will be a very clean minimal, air-cooled, small compact scratch build with a unique design in which I will integrate the new asus rog graphics. so let's start with outlining and cutting the 2 side parts
  6. warboy
    24 Nov 2011
    excellent start;)
    TodMod likes this.
  7. TodMod
    TodMod Minimodder
    14 Dec 2018
  8. TodMod
    TodMod Minimodder
    14 Dec 2018
    :clap: hello guys, now we take care of the realization of the stickers with the new graphic asus rog, which will be applied in the recently cut sides :thumb:
    unfortunately having time to work only at night I have to organize myself with a little more light for the first coats of paint
    MINER MOD ON :grin:
    In the next days I will go to create the vga supports and the attachments that I will go to put in the second piece.
    I gave the first one painted to the first piece to show you the kind of style that the mod will have
    stay tuned :hip::rock:
  9. warboy
    24 Nov 2011
    Beautiful painting. I like the color scheme you've chosen. Very appealing.
    TodMod likes this.
  10. delevic
    delevic What's a Dremel?
    21 Feb 2015
    Most of all I appreciate the manual work. Anyone can cut on a CNC machine :thumb:
    Vault-Tec and TodMod like this.
  11. TodMod
    TodMod Minimodder
    14 Dec 2018
  12. TodMod
    TodMod Minimodder
    14 Dec 2018
    greetings guys!!!
    hear we are again with a new update!!
    now we are dedicated to the realization of the panel in which the motherboard will be allocated, the board that will be the basis for the mod, in which the psu will then be installed
  13. Sa mod pc design
    Sa mod pc design Minimodder
    7 May 2019
    Top work bro
    TodMod likes this.
  14. TodMod
    TodMod Minimodder
    14 Dec 2018
  15. TodMod
    TodMod Minimodder
    14 Dec 2018
    Hello guys
    I immediately set to work on the second flank, going to make spaces and holes for the psu housing.
    and then I proceeded to painting
    now we can try to assemble the parts I've made
  16. Tech Cave
    Tech Cave What's a Dremel?
    18 Sep 2019
    really an awesome job of craftmanship!
    Sa mod pc design and TodMod like this.
  17. TodMod
    TodMod Minimodder
    14 Dec 2018
    Thanks
    Tech Cave and Sa mod pc design like this.
  18. TodMod
    TodMod Minimodder
    14 Dec 2018
    hi folks
    today I show you the finalization of the front part, where I have integrated the rog rgb eye after having folded and assembled the various parts in plex, where the GPU will be attached and positioned with the fan upwards
    Tech Cave likes this.
  19. TodMod
    TodMod Minimodder
    14 Dec 2018
    hi guys the cover for the psu is ready with rgb logo interaction
  20. TodMod
    TodMod Minimodder
    14 Dec 2018
    here we go guys,
    now that all the parts are complete, it's time for the final post.
    Enjoy
    thanks for watching
    warboy likes this.
