News The Steam auto-updater has been changed
Discussion in 'Article Discussion' started by bit-tech, 31 Mar 2020.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Isitari
    Isitari Minimodder
    6 May 2009
    Might be more useful if with a lot of games they stopped them having to be entirely downloaded again just to install a new update.
  3. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Does that actually happen often? I can't say I've noticed. Most updates seem to be a small proportion of the total download size, in my experience.
  4. adidan
    25 Mar 2009
    Can't say that's ever happened to me.
    Mind you I don't have the biggest library.
  5. yuusou
    yuusou Multimodder
    5 Nov 2006
    It depends on the game. PUBG is 9GB every time.
  6. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Presumably the entire download for a new install is still more than that, though?
  7. Mr_Mistoffelees
    26 Aug 2014
    I have Steam but, when you have as many games as I have, bandwidth used by updating is not something to worry about.
  8. Chicken76
    Chicken76 Minimodder
    10 Nov 2009
    Why would that help during this period?
  9. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    If you want to reinstall, you can just drag & drop the folder back and have Steam 'verify local files', rather than deleting the game and having to re-download it.
  10. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    But you can do that just as easily on an SSD as an HDD...
  11. edzieba
    14 Jan 2009
    Sure, but a 2TB SSD is ~£200, whereas that will easily get you 12TB of spinning rust. One will be crammed with your steam library a lot faster than the other.
  12. adidan
    25 Mar 2009
    Dunno, I only ever keep current games on my SSD. No HDD storage.
    The rest, well I keep save games and uninstall the games. I figure if I do play them again there'd be a shed load of updates to install anyway.
  13. Gareth Halfacree
    4 Dec 2007
    I think that's what the article - which, disclaimer, I haven't actually read - is trying to suggest people avoid doing: instead of doing your usual trick of uninstalling the game when you're bored and reinstalling it when you want to pick it back up again, either leave it in place if you've room spare or shuffle it off your main drive onto a secondary drive if you need to free space. That way, if you decide next week you actually want to play it again you're not hammering the server to redownload it.
    adidan likes this.
  14. adidan
    25 Mar 2009
    Never happens to me.
    If i'm done with a game i'm done with it, either for a long time or forever.
    If i'm not sure i'll leave it a while before uninstalling and of course there are one or two i'll leave installed.
    But then that may not be the norm.
  15. Anfield
    Anfield Multimodder
    15 Jan 2010
    Most people don't have a massive steam library, so they can pretty easily just leave everything installed.
    adidan likes this.
  16. adidan
    25 Mar 2009
    Actually, i'm kind of talking crap when I think about it.
    I don't think I actively have uninstalled that many games, I think Elite was the last one but I lost all interest in that.
    If anything I redownload games because I've bought larger SSDs, upgraded my pc and then had a fresh Windows install and redownloaded again.
    No that's crap too, increasing SSD size I just moved the folder to the new one then reinitialised them in the library.
    You know what, don't listen to me. I'm rambling crap.
    #indoorsheadmelt
    MLyons likes this.
  17. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Plus ca change, plus le meme chose
    edzieba and adidan like this.
  18. adidan
    25 Mar 2009
    There is a needle of sense somewhere in my haystack of verbal diarrhea.
  19. Paradigm Shifter
    10 May 2006
    I've done the "copy folder, verify local files" method dozens of times with Steam - sometimes it works, sometimes it doesn't. The worst one was Final Fantasy XV, where it "verified" the folder (something like 120GB with the HD textures) then proceeded to redownload the whole lot anyway. More recently Just Cause 4 pulled the same stunt. I've had other games (most, actually) work without issue though.
Tags: Add Tags
