Hardware Thecus N2800 Review
Discussion in 'Article Discussion' started by CardJoe, 9 Aug 2012.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. barrkel
    barrkel What's a Dremel?
    31 Jan 2007
    If you want more ports than power and ethernet on your NAS, IMO, you're doing something wrong. A box with a lot of disks and sufficient cooling to keep them from overheating won't be quiet enough to keep in your living room.
    But then, I'm definitely not in the target market for these things. I think they're hugely underfeatured and overpriced.
  3. Toka
    Toka Minimodder
    19 Nov 2006
    Really really enjoying my nas + raspi combo, all controlled from iPhone or iPad from the comfort of the sofa. I did consider making a home server instead of the nas but I found the synology much easier to gain SWMBO approval. It just sits amongst the electonic gubbins near the tv, is on 24 7 and just kind of, well, works!
    I would say though, get the synology if you will be sitting in the same room. A noisy nas in this case would make as much sense as a noisy DVD player
  4. Floyd
    Floyd Wire Twister
    4 Dec 2008
    Agreed. I love my Synology NAS! Super quiet and i havent had one issue other than a little slower speeds (30meg) From a 211j box!
Tags: Add Tags
